Old 12-09-2012, 01:29 AM
llleonard4's Avatar
llleonard4 llleonard4 is offline
Vehicle: 2012 Dodge Ram
Trim Level: st
Color: silver
llleonard4 is on a distinguished road
Default mirrors with turn signal
want to change out my plain mirrors on my 2012 ram 1500 st to a set with turn signals and maybe power fold. is it possible to do and if so how can i go about doing it?
2012 ram 1500 st mods include k&n filter, rod rack, tool box, and cb
Old 12-09-2012, 11:10 AM
Hardware's Avatar
Hardware Hardware is offline
Trim Level: Outdoorsman
Color: Black over Grey
Rep:31
I didn't even know power folding mirrors were available for Rams, however it looks like they're an OEM option on 2013 Rams. (scroll down to the spec sheet right after the colour page)
I'm not sure if what you're looking for exactly is available in the aftermarket...
The first step I'd take, (and it would cost nothing to check) is inquire with your dealer on the cost of ordering the OEM mirrors. Be prepared to be shocked but at least that'll give you a starting point for reference. Also check with the service dept and see if the 2013 mirrors could be swapped onto your truck - if it's plug & play that would make things MUCH easier.
Also do an internet search internet search for aftermarket options.
Old 12-09-2012, 09:06 PM
llleonard4's Avatar
Trim Level: st
Color: silver
ok thanks but what about the turn signal mirrors are they just plug and play or is there more to it?
Old 12-10-2012, 05:10 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I could be wrong but my memory is the base model doesn't have the wiring for the lights etc.
Old 12-10-2012, 05:56 PM
Hardware's Avatar
Rep:31
I don't know, that's why I suggested inquiring at the dealership...
Old 12-10-2012, 09:27 PM
TNhemi12 TNhemi12 is offline
Color: Mineral Gray
Rep:18
TNhemi12 is on a distinguished road
From what I've read on here signal mirrors don't work if not factory option and can't be flashed to work
Old 12-10-2012, 09:38 PM
Rep:2657
you might check out this site,
chat with the Specialist to ask about the possibility of Plug & Play
http://www.carid.com/2012-dodge-ram-...m-1107359.html
Old 02-01-2013, 12:26 PM
HEMI2012 HEMI2012 is offline
Vehicle: 2014 RAM R/T
Trim Level: RT
HEMI2012 is on a distinguished road
Talking 2012 Ram ST with blinker & puddle light mirrors
I also have a 2012 Ram ST model I have the regular power & heated mirrors. I wanted to change them to the RT mirrors with the led blinker and puddle light. Asked the dealer at first they said "the wiring harness is different then the PCM need to be changed". Ended up just none of that was a problem there all wired the same just had to change some VIN codes on the PCM from the factory and they work just great.
Old 02-03-2013, 12:53 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
So ST and Express owners can upgrade to heated/puddle mirrors with out too much trouble huh? That's good to hear as mine will be up for sale in a few days.
Old 02-04-2013, 12:14 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
After some research I ordered what was supposed to be the "Flip up" tow mirror for the 2012 1500 Express. When they arrived they were the "Slide Style" so I returned them and tried to order again specifying I want the "Factory Flip Up GPG option code" mirrors. I had found the what I thought were the correct part # but they said they were for earlier year. So they did a little research and found the part # for the 2012 GPG option code.
68143804AB Mirror
68143805AB Mirror
68078242AA Bracket
68078243AA Bracket
The slide out mirrors used the brackets for support so they don't vibrate.the way they install it looks like they will work the new mirrors.If they don't they were only $6 or $7 each. (one less 12 pack)
The mirrors arrived and have puddle and Turn signals.I am waiting for one bracket to arrive, (10 more days) I will then try and do a installation how to with detailed pictures.I will also confirm if the Puddle lights and turn signals are functional on my truck. I will also post the option codes my truck has so other people can confim if theirs are the same so they should then get the same results I do.
If the Puddle lights don't work I will figure out how to tie them into my dome light circuit.
If the turn signals don't work I came across a mod on one of the forms someone had done that used them as marker lights and turn signals.the mod used some relays,diodes and resistors ? to achieve this.
I have made a agreement with service department at the dealership i purchased the truck from to program my computer for all options I add at one time for $130.00 (yes I have it in writing and not on a bar napkin either)
Hope this helps answer some questions.
Almost forgot the mirrors are $387.00 each. Just saw a set on that auction site that is so popular for $325.00 for the pair and $25.00 for shipping and yes they were factory with Puddle and Turn
