Old 12-09-2012, 04:05 PM
dukhunter88 dukhunter88 is offline
Vehicle: 2012 dodge ram 1500 quad cab
dukhunter88 is on a distinguished road
Default double din radio install
OK so ive learned that buying a new truck can def be a pain when you go to buy aftermarket parts anyway maybe someone can help i have a 2012 and im wanting to install a double din. I cant find the dash kit or a wiring harness adapter. Will the ones from a 2011 work? and if so where can i find them at? Thanks in advanced!
Old 12-09-2012, 04:55 PM
Muggus Muggus is offline
Vehicle: 2012 Ram 1500
Trim Level: Express Crew Cab
Rep:15
Muggus is on a distinguished road
Good question. I havent actually looked for one but i do plan on putting a double din in eventually
Old 12-09-2012, 04:57 PM
Ramrodtrucker Ramrodtrucker is offline
Vehicle: 2012 Ram 1500 4X4 Crew Express
Ramrodtrucker is on a distinguished road
i pulled my double in out of my old 2008 dodge GC. They are all the same. you should be good to go
Old 12-09-2012, 05:15 PM
sounds good man i appreciate it. if i get a chance to do it soon ill keep everyone posted so they'll know
Old 12-12-2012, 08:28 PM
buddyleewv buddyleewv is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
Color: True blue
Rep:30
buddyleewv is on a distinguished road
The ones for the 2011 work on the 2012 replaced my HU with a double din kenwood after some plastic and metal trimming behind the dash it fits
Old 12-12-2012, 09:32 PM
Rep:2642
check out the website for CRUTCHFIELD
with full floor console
Old 01-05-2013, 07:35 AM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
everything i needed to install my kenwood dnx 6180 double din nav unit .
http://www.ebay.com/itm/250893302443...84.m1423.l2649
very tight fit -- i used a coarse file to trim down the upper and lower plastic where the unit goes in , and just bent the inner metal opening that the unit had to go through.
the wiring is color match -- directions that came with the PAC are right on ! just put all the wires together as they show -- plug everything in and you are good to go . the instruction show the wiring for alpine system and non alpine -- so non alpine there were a few wires i did not use.
2013 power wagon 2500 - 5.7 everything but leather.
Old 01-06-2013, 09:55 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Another option is having the dash redone to fit the double din:
IMHO it's the only option that can give you a factory look for an aftermarket installation. Doing a search I came across Mike Paustian he has a business called Cosmic Creations. You can see his work on the site. It looks very good as you can see from above. I've been talking to him about a custom project and he has been very responsive. He can use you bezel or he can provide one. There are plenty of options depending on the look you want.
Disclaimer, I don't know Mike and I haven't done business with him yet (the project is still in the planning stages) but I'm pleased with what I see and his communication is very good.
