Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 09-21-2009, 05:43 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
Default Exhaust leaks
I have an 04 and an 05 4.7 qc and both are experiencing exhaust leaks on the left bank. I live in the gainesville area and noone will touch them to repair. I was going to pirchase the bolts from autozone and the guy at the counter advised me to have a pro do it. Has anyone had any issues with the exhaust manifold bolts breaking? Any help on this would be great and if anyone has done this repair before and has pics that would be even better!!!
thanks for reading
Old 09-21-2009, 05:54 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
I hope you have a torch set to heat the bolts. A co worker just did a 5.7 in one of our plow trucks. It was ugly due to the salt the trucks endure.
He heated and let them cool to air temp. and reheated them and worked at getting them free. Bill said it was not that bad of a job once he was done.
thanks for reading
Old 09-21-2009, 07:19 PM
Could be done . The aluminum heads scare everyone . If you have to drill the bolt , just make sure you the down the center of the bolt . Ideally if you could use left handed drill bits would be great . As you're drilling it's biting in an trying to spin out the broken bolt .
Old 09-21-2009, 07:37 PM
Color: grey
Rep:12
The old Ford straight trucks with the 460 in them....the studs would snap at the head from rot and heat. We use to take a regular 3/8 nut and weld the nut to the stud in the center of the nut hole and wrench them out. Glad they stopped making them.
Old 09-22-2009, 09:05 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:98
tmerritt530 will become famous soon enough
I had this exhaust leak on my 04 too. Very common issue on this engine. I took mine in to the dealership under a service contract.
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Cooper Discoverer ATP 285/70R17 | Gibson short tube headers | MBRP cat-back | H/O cams | H/O cyl heads | Transgo reprogramming kit
Old 09-23-2009, 01:27 PM
bigjeff64's Avatar
Rep:20
Originally Posted by tmerritt530 View Post
i had this exhaust leak on my 04 too. Very common issue on this engine. I took mine in to the dealership under a service contract.
unfortunatley both are out of service contracts
Old 09-23-2009, 10:59 PM
fixitfirstime's Avatar
fixitfirstime fixitfirstime is offline
fixitfirstime is on a distinguished road
check the manifold bolts first. Sometimes they are just loose. Go ahead and put some antiseize paste on them while you can.
Old 09-23-2009, 11:23 PM
bigjeff64's Avatar
Rep:20
i havent check the 05 yet however i have looked on the 04 and the last bolt on the left bank the head is completely gone so i dont know if it broke or if it fell out
Old 12-20-2012, 02:26 AM
AlohaRam AlohaRam is offline
Vehicle: 2002 Dodge Ram QuadCab
AlohaRam is on a distinguished road
Bringing this thread back from the dead...
But I'm curious bigjeff64, how'd it go?
I'm about to tackle the same job on my 2002.
Problem is ALL of the 8 studs (on each manifold) will need to be cut off and replaced, due to corrosion ... :/
Old 12-20-2012, 02:36 AM
Rep:2910
Go buy yourself a can of
PB BLASTER
it is on the same shelf as the WD-40 & Liquid Wrench
let it soak in & spray it a 2nd time, then take out the bolts or studs
i also have a BernzOmatic torch & Mapp gas, just in case
KROIL is even better, but you have to go to a gun shop to get it & it is costly
