Cam shaft - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 12-10-2012, 10:25 PM
jakem49's Avatar
jakem49 jakem49 is offline
Vehicle: 1999 dodge ram 4x4
Color: red
jakem49 is on a distinguished road
Default Cam shaft
I'm getting my engine rebuilt in the near future and want some cam lope and more power what would y'all recommend?
if you cant dodge it, RAM IT!!!!!
Old 12-10-2012, 11:15 PM
Dukeboy's Avatar
Dukeboy Dukeboy is offline
Vehicle: 1999 Ram 2500
Color: Red/Silver
Rep:13
Dukeboy is on a distinguished road
I wouldn't install anything that will kill low end power. Remember, the 5.9 is only an 8.7:1 motor. Any "lopey "cam will kill what little cylinder pressure it has.
I'd look into a roller(I assume yours is a roller engine), cam from Edelbrock for towing/RV set ups. We have a Ram 1500 5.9, with a single plane intake and Lopey cam at the shop right now. It's a DOG. Even with a blower. HUGE tires and no torque.
Old 12-10-2012, 11:55 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
I'm figuring you are a bit inexperienced, so I am going to ask this question. Do you want cam lope, or do you want power? Lumpy cams that create alot of lope have alot of overlap and duration. This is for high rpm race cars, lightweight and usually with steep gears and if an auto a really high stall converter.
If it's getting rebuilt, put better pistons in to raise your compression some, between 9:1 to 10:1. What gears do you have? 3.55's do not make for acceleration (your truck probably weighs in the neighborhood of 4600-4800lbs). If I were building a stock displacement 360 for your truck, I would put in the better pistons, arrange for matched stall torque converter to go with the cam and gears. 3.92's would help, 4.10's or 4.56's would be better. Hughes Engines is one of the best places to talk to about cam selection. You need to match it with the gears and converter you intend to use. Since you are rebuilding the engine, have you had the trans looked at? It stands to reason if you have a fresh engine making more power, you will break your however-many-miles-it-has-transmission. Think of everything working together as a 'system', not just the engine making all the power.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 12-13-2012, 03:14 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Something to remember is that you will improve one area and sacrifice another. For example a whiplash cam will be very torque-plenty. You will drop off in horsepower however. On the opposite end of the spectrum, some cams make good power and lose torque. In order to help counter this you'll need a proper tune and look into maybe a new intake manifold, throttle body, valve springs, headers.
Supplying mods with a camshaft are pretty much necessary.
Old 12-13-2012, 07:31 PM
jakem49's Avatar
Color: red
preciate it guys yeah im a lil inexperienced haha but it wontbe rebuilt for a while thanks for the input!
Old 12-14-2012, 08:23 AM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
Yeah, nothing sucks any worse than having a truck that just sounds like it runs well, then being asked to prove it, only to be outperformed.
Old 12-17-2012, 01:36 AM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
check this vid out of my bolt on and cammed/heads ram lunati custom grind cam LET ME TELL YOU THE POWER OF THIS BEAST IS AMAZING
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 01-07-2013, 07:17 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
Hemilonestar, could I trouble to you give me advice in my post over in the 5.2 section. It's about cams/heads/piston combo. TIA
Old 01-07-2013, 10:23 PM
ram150059 ram150059 is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: Slt Lariat
ram150059 is on a distinguished road
Im looking to put a towing/rv cam in my ram 1500 with the 5.9. i was thinking of getting the msd 6-a, doing the kegger mod, rockers, headers to a straight exhaust side exit, and doing an sct chip. its stock suspension for now and im not a fan of lifting. has a fresh tranny in it so now im looking to get a little more power and that perfect rumble. Any input on this would be much appreciated. Im wondering what lift/ duration to go with as well as the information on the 1.7 rockers.
Old 01-12-2013, 09:42 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Most cams actually are not compatable with 1.7 rockers, best to keep 1.6. It's either or. A good cam for low end is Hughes 0814 cam and can be done with stock heads.
