Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 12-16-2012, 10:44 AM
Zevox's Avatar
Zevox Zevox is offline
Vehicle: 2014 Ford Mustang
Trim Level: GT
Color: Race Red
Zevox is on a distinguished road
That's strange. What gearing and tire size did you have? If you had 3.55's and stock ~31" tires shifting out of 2nd prime ~5600rpm would put you at ~100mph+. Not sure why that would be needed unless you had a really fast truck.
My truck in manual mode forces a shift from 1-2 at 5600rpm, my programmer didn't even over ride it correctly for a while. That being said, it will not shift from 2-3 unless I shift it. The only gear my truck has ever forced a shift in is from 1-2 while in manual mode.
Old 12-16-2012, 11:00 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
So you guys have actually run your truck through the gears to the point where it will just bounce off the rev limiter and won't shift?
I haven't done that, because that's hard on the truck, but it is not SUPPOSED to do that. But not saying you guys are lying, just that the pcm is supposed to prevent that from happening.
Sean
Old 12-16-2012, 04:10 PM
Zevox's Avatar
Trim Level: GT
Color: Race Red
I did it when I first got my truck and didn't know 3rd gear only lasted like 1000rpm... To clarify, it does shift but you have to shift it. The truck won't override your gear selected gear. (Just making sure you didn't think the truck was locked into a gear.)
Old 02-09-2013, 12:14 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Originally Posted by UNBROKEN View Post
If you have the console you can just hold it to the left and it'll shift through all gears at redline.
If you do this will it even hit 3rd gear?
SPONSORED BY
BULLY'S PERFORMANCE
