Old 12-21-2012, 03:22 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
well hopefully because you have a 2012 everything isn't all seized up like on mine. My was a PAIN took me a week.
Old 12-21-2012, 03:36 PM
Rep:1804
I am going to do them myself, just the alignment will need to have it done LOL
Dont think Asur will have this issue.
He lubes all his bolts
Old 12-21-2012, 04:02 PM
Asur Asur is offline
Vehicle: .
Rep:4373
yup, Jeep 12 years later was so lubed all the bolts were still easily removable. I used this stuff on all my bolts
Old 12-21-2012, 04:54 PM
Rep:1804
Thought you use a different one?
I bought the one you recommended from Canadian Tire
Old 12-21-2012, 05:31 PM
Vehicle: .
Rep:4373
I also use fluid film
Lithium Grease, the white stuff.
and another stuff based on bees wax
but this stuff is also great on bolts as it will destroy any rust that forms, seams, bolts, between diff types of material, etc, but any of the above will save yourself a ton a trouble, especially in our type of climate.
Old 12-21-2012, 07:07 PM
Rep:1804
Yes.....Lithium Grease is what you told me to get
Is that still ok?
Old 12-21-2012, 11:11 PM
Vehicle: .
Rep:4373
Is that still ok?
yes, lithium white grease is one of the best products to use all over the truck, if there are places you would like something that is more transparent, use the rust cure, it is transparent and easy to remove in the summer. I use all three products all over the truck.
Old 12-21-2012, 11:23 PM
Rep:1804
So you remove the grease in the summer?
Sounds like a lot of work. Lol
Old 12-22-2012, 10:52 AM
Vehicle: .
Rep:4373
In the fall i spray everything, every bolt I can see or find, under, engine area etc, the thing hear is if you want to have a spic and spam engine compartment it may not be the way to go, so you might want to only spray in area's you don't normally see. Like all the bolts under the truck, top plate bolts etc. In the spring, I go over those again, just re-spray over where I have gone before in the fall, all the door locks I spray in the fall, all the those bolts etc, in the spring any area that my be visible is cleaned, I just wash my truck and use an old mit to clean the area's that may have a lot of grease still left over from the winter, so door hinges, lock area's, stuff like that, I use fluid film in my hitch, that stuff does not come off easy. So things like body bolts, step bolts and hardware, brake lines and connectors (these trucks the brake lines and fuel lines are covered in plastic, but the connectors to the calipers lines are not) so I cover them in lithium grease also. In my engine bay, all the bolts are done, I use both lithium on bolts I don't really see, and Rust cure is transparent on bolts that are visible. As you do it every fall and spring, you figure out what is best
Old 12-22-2012, 11:32 PM
Rep:1900
this makes me feel like I abuse my truck :/
