CEL shows misfires but no misfire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-12-2012, 12:00 AM
eddie7644 eddie7644 is offline
eddie7644 is on a distinguished road
Default CEL shows misfires but no misfire
I have a 97 1500 5.2L. The problem im having is i keep getting misfire codes, random misfire on all cylinders. There is no obvious misfire I mean I dont feel anything the truck runs great. I will clear the codes and when I get on it like merging onto a highway the CEL will flash then stay on and show all cylinders randomly misfiring. I have replaced cap, rotor, plugs, wires, crank sensor, distributor, hollowed cat. Like I said you do not feel any misfire it runs great. Any ideas would be greatly appreciated!
Old 12-12-2012, 10:49 AM
Resident Technician
Rep:1915
What codes are you getting and have you replaced the intake manifold plenum pan gasket?
Old 12-13-2012, 12:33 AM
I am getting PO300-308. Yes I replaced the gasket I actually bought the Hughes upgrade aluminum was I also replaced the fuel pump, MAP sensor, IAC valve and TPS.
Old 12-13-2012, 01:47 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
How many miles are on the O2 sensors? O2 sensors can create a bunch of problems.
Old 12-17-2012, 02:27 PM
Maybe about 50,000 on them
Old 12-17-2012, 04:56 PM
panhead's Avatar
Rep:103
Hm, there about due but shouldnt cause a misfire. Did you make sure that the cap is screwed in tightly? Make sure none of the wires are loose and rubbing on each other.
