Old 12-12-2012, 12:53 PM
homerkill homerkill is offline
Vehicle: 2011 dodge ram
Trim Level: EXPRESS
Color: BLUE WATER PEARL
homerkill is on a distinguished road
Default Moes 85mm throttle body install ??
what tool or tools should i need to install my new TB??? i put on my afe bymyself and i was just wondering do i have to take off my hemi hat to do so??? thanks guys...
Old 12-12-2012, 12:58 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
It's really REALLY easy. First you can use a flat head screw driver to loosen the clamp that holds the intake onto the TB. Then just pull the intake off the TB.
For the Hemi Hat just gently pull up and pull it towards you and it will come right out. Just push the hoses down that are underneath it.
For the TB itself it has four bolts and the electrical connector. I think the bolts are 7MM... not 100% on that. They aren't very tight at all. Take those four out and disconnect the connector and that's it.
Swap, replace, and your done!
Chrome... in moderation.
Old 12-12-2012, 02:41 PM
bighemi04's Avatar
Rep:623
And Arth strikes again!
Old 12-12-2012, 08:22 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Thanks for the info! I will be sure to use it when I get back from michigan! (all of my self bought presents are coming back with me )
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 12-13-2012, 04:28 PM
jgregg6 jgregg6 is offline
Vehicle: 2005 Dodge Ram 5.7 Hemi
jgregg6 is on a distinguished road
I'm thinking about buying a Moes 85MM throttlebody as I'm still hunting for a little bit more mpg. Yes yes I know it's a hemi and that it's not a hybrid but I'm still looking for some more mods for hp and a tad more mpg. Right now I have a S&B CAI and just got a Diablo Intune sport programmer that I'm currently running on the 87 tune with 89 octane. And I also went down from 305/60/20's to 275/60/20's (so much smoother ride). Any help is useful! I've been told to get one but I really haven't done much research on it myself.
Flowmaster exhaust, S&B CAI, DiabloSport tuner, Moes 85mm TB, Rhino Nerf Bars, 20" Moto Metal
Old 12-13-2012, 09:22 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Change to the 93 tune and you will get better mpg, but at a higher cost for premium. I would also recommend switching to 100% gas versus the ethanol version. It will cost slightly more, but will give you results that are measurable. Here is my test that may be helpful to you.... http://www.ramforumz.com/showthread.php?t=102343
Old 12-13-2012, 11:48 PM
Hey thanks so much for the reply! I'm going to do some looking around tomorrow after work and I'm sure I can find atleast one gas station around here to fill up at! Also, I noticed in some of your posts that you were running the 93 tune on 91 octane? I've read places where guys are saying that your tune should never be higher than the octane? Thoughts?
Once again thanks for your input! Ohh and the test you did was great!
Old 12-13-2012, 11:59 PM
Exactly this!
Easier than a cabin filter mod.......seriously though
Old 12-14-2012, 06:06 AM
clum553946 clum553946 is offline
Vehicle: 2012 Ram Big Horn Crew 4X4
Rep:24
clum553946 is on a distinguished road
Wouldn't a larger throttle body worsen gas mileage?
Old 12-14-2012, 11:11 AM
Trim Level: EXPRESS
thanks guys!! one more ?... does the moe's 85mm throttle body come with bolts or can i use the same factory bolts on the old throttle body.. thanks u guys are awesome sauce!!!!!!!
