Old 12-14-2012, 10:55 AM
Originally Posted by clum553946 View Post
Wouldn't a larger throttle body worsen gas mileage?
It actually improves it slightly as the stock TB is restrictive.
Originally Posted by homerkill View Post
thanks guys!! one more ?... does the moe's 85mm throttle body come with bolts or can i use the same factory bolts on the old throttle body.. thanks u guys are awesome sauce!!!!!!!
You use your stock bolts.
Typically it is a stock TB (well Moe's is) and its simply machined and ported out.
Old 12-15-2012, 06:00 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
What one do ya'll think is best, fastman, BBK or Moes???
SPONSORED BY
BULLY'S PERFORMANCE
Old 12-15-2012, 07:37 PM
I havent used any of the 2 other than Moe's.
Many have switched from fastmans to Moes's.
Worth looking into
BBK I heard throws codes......read up on that to as I may be wrong
Old 12-16-2012, 01:12 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Any photos
what tool or tools should i need to install my new TB??? i put on my afe bymyself and i was just wondering do i have to take off my hemi hat to do so??? thanks guys...
HOmerkill - did you manage to get any photos of your install and the new TB?
Old 12-16-2012, 01:26 AM
This is a simple install.
Remove your hose leading to your air filter box as it sits right on top (clamped) to the stock TB.
There are 4 bolts holding it down
Unscrew them, and disconnect the plug.
Replace with new one and reverse order the above
Literally takes 10mins
Old 12-16-2012, 05:13 AM
homerkill homerkill is offline
Vehicle: 2011 dodge ram
Trim Level: EXPRESS
Color: BLUE WATER PEARL
homerkill is on a distinguished road
thanks guys.. one more question.. what size of socket does the bolts take? 6mm or 7mm socket? also would it be allright to not remove the whole air filter house and just unclamp it from the TB... also would it be ok to disconnect and than remove the bolts.. sorry for all of this.. i wanna get things right!
Old 12-16-2012, 11:51 AM
Correct! Simply remove the clamp from the hose attaches the TB. If you still have the stock hose, it's flexible, so move it aside. You can either disconnect it before removing he bolt or vice versa. Makes no difference.
I think it's a 7mm or 8mm socket. But it is one of those 2
Old 12-18-2012, 01:01 AM
bootstrap23 bootstrap23 is offline
Vehicle: 2012 Dodge Ram
Trim Level: Sport CC 4x4
Color: Tequila Sunrise Pearl
bootstrap23 is on a distinguished road
is this TB worth getting if you only have the following MODS: CAI, Y pipe, 14" muffler? or when would you really consider changing the TB?
Old 12-18-2012, 01:16 AM
Let me put it this way....
When. Installed it, the truck felt lighter on its feet, possibly due to the better throttle response.
But. Thought it was it my head. Plus I only drove 20-30miles on it before selling it for an 87mm (waiting for it)
Reverted back to stock and boy, what a difference. Noticed it more going back to stock. So yes, it's worth it IMO
Old 12-18-2012, 01:30 AM
thanks! still up in the air about it
