Old 12-12-2012, 07:56 PM
AladdinSane's Avatar
AladdinSane AladdinSane is offline
Vehicle: 2012 Ram 1500 4x4 Quad Cab
Color: Blizzack
AladdinSane is on a distinguished road
Default 275/60-20 vs 275/65-20
Can I run this slightly taller size on my stock 2012 4x4 QC without a level kit and or lift or should I stick with the original size until I make that leap? These stock tires have to go soon and I would like some more rubber!
Thanks!
Old 12-12-2012, 10:20 PM
Mozeby's Avatar
Mozeby Mozeby is offline
Rep:39
Mozeby is on a distinguished road
Thanks!
You're adding an inch in tire height so I think you'll probably be fine since it's really only a 1/2 inch that is now closer to your fenders and wheel wells. I personally would also do the level kit since the front will look even more stuffed now with less gap.
Old 12-13-2012, 01:56 AM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
Thanks!
Yes you can, but 275/65r20 is not as common a size, so it's more expensive than the 275/60r20 size.
Old 12-13-2012, 02:34 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
There only slightly taller and the ram has plenty of room for only that small difference in height.
Old 12-13-2012, 07:02 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Agreed. You can run that size with zero issues. You could actually run a 285/65/20 without any issues, although it is a 34.5" tire and a leveling kit would probably make it look a little better. Only thing about the 285/65 is that there are only two tires available in that size, the Goodyear Wrangler Duratrac and the BFG T/A KO. Yes, the 275/65 is more expensive than the 275/60 but you better be sitting down when you look at the price of the 285/65, lol.
Old 12-13-2012, 07:34 PM
Color: Blizzack
Thanks for the help and suggestions. I think I'll stick with the stock size for now and an AT tire for winter and sand driving. A lift at least is coming. Never realized how low the front sits until I got this truck.
Old 12-13-2012, 08:10 PM
smitty0486's Avatar
smitty0486 smitty0486 is offline
Vehicle: 2014 Ram 2500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
smitty0486 is on a distinguished road
a little off track from the 20" tires, but if the 285/65/20 will fit what about a 285/70/17 or the 315/70/17?
Old 12-13-2012, 08:35 PM
Color: Blizzack
I've bounced that idea around in my head as well. Love the 20" wheels but really used to less rim, more tire. If money were not an issue I'd have a set of both.
Old 12-13-2012, 08:51 PM
Rep:367
A 285/70/17 should fit on a third or fourth gen with no problems. It's only one size wider and actually a hair shorter than the stock 20" tire size.
A 315/70/17 will not fit on a 2006-up truck without spacers or aftermarket wheels with less offset (or more negative offset). I believe you could fit this size on a 2005 or older truck. Everything I have read indicates that you can run a 35x12.50 on these trucks and a 315/70/17 is only 12.4" wide and 34.3" tall.
Old 12-13-2012, 09:40 PM
smitty0486's Avatar
I work at a scrap yard and lucked into a set of factory 17" wheels a month ago, a guy bought a new set for his ram and sold his old stock ones for scrap so i got them for free and im thinking about going woth the 315/70/17's for a more aggressive look and maube keeping the stock 20's and tires to switch over to during the warmer months!
