Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 12-12-2012, 10:42 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default nitrous for my little 4.7
My RCSB 4.7 running 14's is due for a nitrous setup in Jan. wondering you all's opinions are. Looking to run a 100 shot. I want more but idk how much this engine can handle. Also looking for plugs. And a custom HEMIFEVER tune for the nitrous.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 12-12-2012, 11:14 PM
Color: Gloss Black
Rep:141
Old 12-13-2012, 07:44 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
nice lift!!! look at the zex wet setup..pretty safe for your setup..
Old 12-13-2012, 08:36 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
You should be fine with a 100 shot. I try to run 1 grade better gas= 93 when spraying, 91 octane tune. I gap my plugs a bit closer, and run 1 range colder. Brisk makes nitrous specific plugs, but I just run either Champions or NGK's in my hemi. I never spray below 2800 and only at WOT. Should knock your times down a lot. Now go whoop on some EcoBoost and Tundra owners. Expect to hear a lot of whine when they lose to a lowly 4.7 Mopar.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-13-2012, 08:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Hey bud! I'll try to help you out with the plugs again. It's crazy how much of a PITA it has been trying to locate proper plugs for your application.
The 4.7L is a very strong engine, I'd look at whatever the hemi guys are spraying and would think that you'd be just as safe, and probably safer doing the same. The 4.7L uses a crank girdle, not individual main caps, and also the pistons I believe do not have the thin top ring land that is the common issue for the hemi.
Sean
Old 12-17-2012, 05:22 PM
Color: Gloss Black
Rep:141
So WOT switch? over window?Sean: where we at on the plugs? lol i was suggested Tr6 NGK plugs. Thanks for the info hydrex
Old 12-17-2012, 05:25 PM
Color: Gloss Black
Rep:141
Thanks! , yea i was looking at zex and a nitrous outlet setup, also a universal setup from NOS
Old 12-17-2012, 08:06 PM
snrusnak's Avatar
Rep:1385
Oh boy, here we go again lol...
I really wish I had access to a full catalog of plugs for a given manufacturer. I'll get back to searching...
Not sure what plugs you're referring to, got a part number specifically? And this is for the exhaust or intake side?
Sean
Old 12-17-2012, 09:06 PM
snrusnak's Avatar
Rep:1385
Well this is really weird.... it looks like bosch is no longer making one of the plugs for the 2008+ 4.7L.
Stock plugs are as follows:
Uppers.......FR8TE2
Lowers.......FR8T1332
The lowers(FR8T1332) are no longer found on bosch's website.
I have to search more. Basically, I think what you're going to end up wanting is an iridium plug one heat range colder than stock for the exhaust side(make sure projection and threads are same). And then a copper plug one heat range colder than stock for the intake side(make sure projection and threads are same).
Finding out specifically what those are is a little more difficult...
Sean
Old 12-18-2012, 11:07 AM
Color: Gloss Black
Rep:141
Can't I just replace the intake side? Or no?
