Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 12-13-2012, 03:54 PM
Red Grimm Red Grimm is offline
Vehicle: 1994 Dodge Ram 1500
Red Grimm is on a distinguished road
Default 94 Ram 41 Crank Pos Sensor
I have a 1994 Dodge Ram 1500 4wd that I am having a horrid time with. My truck has been down for over a month and am still stumped. I've replaced the PCM, ASD relay, and the crankshaft position sensor.
I'm not a mechanic by trade however I do my own work. I have checked OBD codes at first it pulled 7 after I replaced the PCM it narrowed down to 3 codes: 12, 41, 55. 12 being battery diconnected from PCM within last 50 key-on cycles. 55 Code completion. 41 Problem with the charging system. Occurs when voltage from the ASD relay is below 11.75 volts.
I then replaced the Crankshaft Position Sensor due to code 41 (PITA). I don't know if maybe I mixed up a few plugs, but I started her up and she sputtered, ran for a bit, then died. I then pulled codes came up with 5 codes: 12, 45, 37, 41, 55. 45 Transmission OD solenoid malfunction. 37 wasn't in my book, but found it online: Part throttle unlock circuit. For the see above.
My next step is to recheck my plugs. Am I missing anything? Because I am at a loss.
crank sensor, obd 1 code 41
