Old 12-14-2012, 12:29 PM
Jon3sgte Jon3sgte is online now
Vehicle: 2012 Ram CC
Trim Level: Tradesman
Rep:30
Jon3sgte is on a distinguished road
Default About to add an amp questions...(OEM HU)
I've got just about everything I need for the install. Just a few questions: To PAC or not? My amp has High Level inputs. Where to tap into the rear spkrs? If I use a PAC, wont I need to tap into both L/R spkrs? I'd like to get a clean sweep or something like that but it's 2 weeks before Christmas and I've been itching to get the system in. Any all help/recommendations would be greatly appreciated. Help me get this system in!!
Old 12-15-2012, 06:39 PM
Taylor15835's Avatar
Taylor15835 Taylor15835 is offline
Vehicle: 2010 ram 1500 sport
Trim Level: sport
Taylor15835 is on a distinguished road
I installed a JL in the rear in place of the stock sub. I used a PAC an tapped into the rear right speaker, most places like best buy or speaker places recommend the rear left, i asked why and they said idk just something that most people do... PAC only taps to one speaker the wires an be found on either side running through the tower where you seat belt is and then into the door.
Old 12-17-2012, 12:14 PM
Rep:30
^wouldnt only tapping into one side only give you a L or R signal?^ Thanks for the heads up on the wire location! One more question, where to tap into to for the Remote/acc?
Old 12-17-2012, 04:10 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
PAC or LOC? When I think of PAC, I'm thinking $100+ adaptor/harness that plugs behind your OE HU to give you RCA outs (PAC C2A-CHY23). For a Line Output Converter ($10+), you'd have to find some speaker level inputs to tap into, and run a remote turn-on. I would think you'd need at least a right and left set. I've always used both. I've never had good luck with speaker-level inputs on amps, but that was many years ago.
Old 12-18-2012, 11:13 AM
Rep:30
Yes, a LOC. The one I was looking at is made by PAC. Sorry for the confusion. My amp does have the speaker level inputs but I am going to avoid that route. Where is everyone tapping in for the rem/acc?
Old 12-19-2012, 08:31 PM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
yea i need to know where to tap into for the remote as well
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
Old 12-19-2012, 10:00 PM
Trim Level: sport
if you use fade r or l thats the only time the signal would be different for the rear and as far as a remote wire, i had trouble finding one so i went to the front fuse box and tapped into one of the ignition/key wires, you can use a wire tester to find a fuse that is only on when the truck is running.
Old 12-20-2012, 05:04 PM
Color: Sagebrush
Rep:87
I had a hard time finding an accessory tap when I hard-wired my radar detector. I finally found +12V on the smallest brake controller harness. The harness may be there even if you don't have the brake controller. I had lots of empty harness plugs under my dash. The cig lighter is also keyed. You could tap into it for the REM.
Old 12-21-2012, 11:24 AM
Rep:30
^Thanks for the replies^ Hopefully I can get the system in this weekend.
