Old 12-14-2012, 06:40 PM
11hemisport 11hemisport is offline
Vehicle: 2011 dodge ram sport
Trim Level: sport
Color: blue
11hemisport is on a distinguished road
Default Efan installed. Trinity temps?
Installed my tyc efan yesterday with ease.
I am still using the stock t-stat and set all temps on the trinity to 195, but I think that is too low...
Anyone know what the stock t-stat opens at? I think I would want to be about 5-10 degreas above that for fans on
Old 12-14-2012, 08:43 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Stock t-stat opens either at 203 or 204.....I have a 180tstat and I have my setting at 183.99 and 187.99 just fyi so I think 207 and 211 should be where I would set it at.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 12-14-2012, 08:58 PM
Trim Level: sport
Color: blue
Ok.
I set them at 195 and temp still climbed to 202..
Makes sense now
Does your fan function in high and low speed ??
Some with the tyc and trinity say it only operates on high
Old 12-14-2012, 10:07 PM
Rep:111
You know I don't really know for a fact but I have the tyc fan also but I've never hit 187.99 degrees the high speed it set on. My setting like I said were 183.99 low 187.99 high and usually my temp sets at 183 to 185. So I'm assuming assuming it does have a low speed and high speed. I haven't had it in that long maybe a month since we never had tuning for the 11s..... I guess when it starts to heat again I'm sure I'll find out.
Old 12-14-2012, 10:57 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
TBH's truck is very fast so I don't want to sit here and say he's wrong, and I'm not extremely familiar with the setting adjustments with the trinity, what the actual opening temp for the hemi 180 tstat is, etc.... what he is doing is obviously working.
But just keep in mind you want to have the efan running as little as possible, because if it is running then it is using hp(via the alternator). It's not exact, but having the efan run you can say you are using roughly the same hp as the clutch fan being engaged. The benefit of this mod is to have the fan not running.
Sean
Old 12-14-2012, 11:11 PM
Trim Level: sport
Color: blue
Exactly.
My thinking is that 5-10 degrees above the stock t-stat open temp is when the fan should kick on. Right now it comes on before the thermostat is open which is why the temps continue to climb... Once t-stat opens, coolant does its thing and ect drops fast, back to 195
This mod was super easy to do with the use of an air hammer and seems to suit my I town driving very well.
For all people in Canada, I purchased the fan from van and truck world for 209 CAD.
Old 12-14-2012, 11:16 PM
snrusnak's Avatar
Rep:1385
Personally my 180 deg (advertised) tstat opens at ~187 deg (actual) and I monkeyed around with my fan on temp settings for 6 months + and then ended up setting it around 203 deg. So it would come on at 203 deg(after sitting idle for like 5 minutes only would it get that high) then turn off at like 195. With this setup the fan very rarely was running, and it was just when sitting idle that it ran. The truck ran cooler at all times still, as compared to stock. I recently put the settings back to stock and put the clutch fan back on, just because I don't really notice any difference. I left the 180 tstat though and the efan almost never runs.
Sean
Old 12-15-2012, 11:08 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
All I did was take the stock temperatures and reduce them by 23 degrees each, as that is what changing the stock thermostat down to a 180 degree thermostat changed. I have no problems. This is on my Super Bee though.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 12-15-2012, 02:20 PM
Trim Level: sport
Color: blue
So the stock temps from where?? The trinity ?
Old 12-15-2012, 03:17 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
Does the Trinity control both fan speeds?
