Driveshaft - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 12-14-2012, 09:10 PM
Metallifan Metallifan is offline
Vehicle: 2001 Dodge Ram SLT
Trim Level: SLT Laraime
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:28
Metallifan is on a distinguished road
Default Driveshaft
Just bought an 88 Dodge W150 4x4 and on the drive home, the rear driveshaft snapped in half due to rust. Where can I get another one and do any other Dodge vehicles have the same shaft I could use?
Weird thing is, it didn't have a slip yolk where it goes into the transfer case, I thought they all did.
Old 12-14-2012, 10:58 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
this would be your best bet here http://www.carpartsdiscount.com/auto...html?3594=2089
or you could always check out your local pick n pull. we can get you one from a1 manufacturing it is a little more expensive and also has a $53 core charge.
hope this helps
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 12-14-2012, 11:07 PM
Rep:28
None of my local junkyards have these old Dodges in them. I need the entire rear driveshaft assembly, I can only find the front driveshaft online.
Old 12-15-2012, 08:39 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
I've had this same problem with my 1988 chevy k5 blazer. the rear driveshaft splines (not a slip yoke driveshaft) were sloppy and caused a horrible vibration. I couldn't find a rear driveshaft if my life depended on it. I had to have a custom one made by a local driveline shop. Cost around $200.
You could always search ebay or craigslist
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 12-16-2012, 02:07 AM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Get one made at a drivleine shop, they know what they are doing and will make it right.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 12-16-2012, 02:22 AM
Rep:28
I have, but why would I put $200 in a truck I paid $1,000 for?... I guess if I ABSOLUTELY had to... I found one in PA online, I live in OH. $75+$50 in gas with my little 5 speed Corolla. I'd rather do $125 than $200.
Old 12-16-2012, 02:37 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
No you don't want to do that... If new is $200, you're better off new. That $125 driveshaft is going to take your time to get there and back, and that's worth more then $50. It'll probably need to be balanced too. How much will your local driveline shop charge for balancing?
Old 12-18-2012, 03:35 AM
Rep:28
I'm going to use this truck as a snow and mud truck. It's not my daily driver. Why would it need balanced? It's a used one pulled off an 87 W150.
