Old 08-07-2013, 09:47 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Glad I could help out a bit.
Also glad to hear the oil was from the plugs not the rear seal.
If you need a hand today,Im off work around 11:00.A.M.
Give me a shout.
Cheers.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 08-07-2013, 11:51 AM
fastNugly @ BP fastNugly @ BP is online now
Give me a shout.
Cheers.
Amazing to have local help ^^^
Anyone wanna fly out to Toronto to do mine?
Old 08-09-2013, 12:50 AM
I push the skinny pedal
Rep:3277
I'll fly out... you just have to pay the ticket
I'm getting frustrated with Josh at HHP, I still don't have a startup tune yet. It's been sitting in the U-wrench for the past 4 days and it really should have only been in there for 1 day if I'd had the startup tune. Since I've been waiting for the tune I've decided to go ahead and do a few of the other mods I have sitting in the storage unit. I'm in the process of installing my drop kit, so I've got the Ground Force front springs in already. I had ordered some Belltech shocks, but they sent me 2wd shocks instead. I can use the rears but the fronts are useless to me.
While i had the front shocks out I decided to try an experiment... swapping McGaughy's spindles onto a 4wd, and they physically fit, but it's obvious my upper balljoint is in a very extreme situation since the McG's spindle is 2.5" shorter than the 4wd spindle, so I'll be designing a new upper control arm to even everything else out, aside from that the lower portion of the spindle works great with the 4wd suspension. I might see if I can't convert to a uniball or spherical joint rather than a balljoint, as it would take more extreme angles. I'm going to leave the spindles in with the GF springs and see how long my CV joints hold up if I ever get the engine running.
Tomorrow I tackle the rear springs as well as the Spohn adjustable control arms and panhard bar. I may have to cut the rear springs eventually just to get the trim I want, but that will happen in time.
Kurtis
Old 08-10-2013, 01:31 AM
Rep:3277
Soooooo..... still not running. Got my new tune from Josh. He had taken the day off to be with family but when I called HHP they got a hold of him at home and he did the tune from home. Sadly I believe it is a physical issue, not a tune issue. I'm pretty sure that my timing is off as I'm only making 2-4psi of compression in cylinder 1.
However, I did get the truck's stance to where I wanted it. I might trim the rear coils to bring the back down more, but using the Belltech 2WD stock size shocks was exactly what I wanted with the McGaughy's 2wd rear drop springs. Here's everything that I pulled out of the truck in the last 2 days
Swapped out the rear sway bar for a Hellwig bar at the same time that I did the rear Spohn control arms and panhard bars.
There's a slight length difference between the stock 4wd and the 2WD Belltech shocks
Here's the difference between the stock 4wd steering knuckle and the 2wd McGaughy's steering knuckle. There's an overall 2.5" height difference between the two and it results in an extreme angle on the upper balljoint. I have been in touch with Michigan Metal Works and they make a replacement upper control arm with a spherical joint for this exact purpose, dropping a 4wd lower than 2" in the front.
Kurtis
Old 08-11-2013, 09:44 PM
98hemi-ram's Avatar
98hemi-ram 98hemi-ram is offline
Vehicle: 98 Dodge Ram
Rep:112
98hemi-ram will become famous soon enough98hemi-ram will become famous soon enough
Looks like you've got a lot done but where is the pics of the while truck with its new stance? :P
98 Ram 1500 rcsb 2wd - 5.7 Hemi swapped with many upgrades
All mods listed in my profile
Old 08-21-2013, 12:24 AM
Rep:3277
No pics of the new stance until it's running and I can give it a bath. More than a month of being outdoors and no ability to get it to a wash bay, I'm ashamed of how dirty it is right now.
I just had it towed to my friend's shop so I can get started on it again tomorrow, so hopefully it's running either by the end of the day or by tomorrow at the latest. In the mean time, I took a day off from the mechanical stuff and relaxed and did some fiberglass work and some prep/paint.
Filled in the lower RAM insert and smoothed it all out
Coil pack covers painted, just waiting on clearcoat
The start of the fiberglass work on the lower console. I'm smoothing it out and will be running my nitrous pressure gauge and master switches from here.
The inserts... painted to match the new body color
Kurtis
Old 08-21-2013, 01:09 AM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Cheap Canadian Labour
Rep:1808
Looking good can't wait to see the whole interior together it will be pretty sharp
Old 08-21-2013, 09:46 AM
Rep:3277
Me too. If I get the truck running today it'll be game on for some more mods, if not then it'll be back to banging on the engine block with a bigger hammer.
Kurtis
Old 08-21-2013, 10:32 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Very sweet man, great work as always.
Old 08-21-2013, 11:55 AM
Kurtis, The day you truck is done....Ill be drooling over it.
These pics are teasing that end result.
Cant wait to see it
