Old 12-15-2012, 10:24 PM
hemirae hemirae is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie CC
Color: Black Crystal Pearl
hemirae is on a distinguished road
Default To those who had upgraded only the sub - I need help!
I have premium alpine system with RER HU. I had recently replaced my stock sub system with JL Audio 250/1 V2 and JL Stealthbox and the delay on the sub was very noticeable that the sound system as a whole sounded worse than before the change. I tapped the 4 sub wires and connected to amp at speaker level. I tried all the recommended adjustments for the JL combination and could not make it blend right with the OEM system.
It was annoying so I uninstalled the JL combo and reinstalled the stock sub - sounded better as a whole system.
Old 12-17-2012, 04:17 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
I have not heard of similar issues. It sounds like it may have been out of phase? Did you double-check your input/output wiring -- make sure you had the OE color codes correct? Maybe try an LOC instead of the speaker level inputs.
Old 12-17-2012, 08:17 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I use a LOC and have no such issues. I am actually using an aftermarket amp with the stock sub and it sounds good enough for me. I did not want to give up the stock setup with the underseat compartment cover.
Old 12-17-2012, 09:45 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
I too am using a LOC with an additional aftermarket amp and sub. Have had no issues at all with sound and delay...
Old 12-18-2012, 02:09 AM
thanks for the replies. i will try to use loc. i am considering Cache coe6 that i currently on sale at Sonicelectronix for $70.
Old 12-20-2012, 05:11 PM
Color: Sagebrush
Rep:87
I'm sure it would work, but seems overkill if you're only adding a sub. I guess you could leave the additional 4 channels for expansion. I have a cheap 10-$15 one from Sonic -- with built-in remote turn-on. It worked great in my previous ride. I hope to use it in my Ram as well.
Old 12-22-2012, 12:49 PM
Color: Black (PX8)
Rep:388
Yep, PAC SOEM-T is what I used. Works great. Has remote turn on that works off speaker input. No issues.
Old 12-24-2012, 05:40 PM
I am planning to add also a 4-channel amp.
