2000 Ram 1500 w/5.9 won't start when warm - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-16-2012, 01:01 PM
mdb mdb is offline
Vehicle: 2000 Dodge Ram
Trim Level: Laramie (?)
mdb is on a distinguished road
Default 2000 Ram 1500 w/5.9 won't start when warm
I bought my son a used 2000 Dodge Ram pickup. It was running find until recently. It starts up fine in the morning but after about five minutes of driving (even idling in the driveway) the idle will get rough, I can hear what sounds like a vacuum leak, and it will die. After that it will turn over but not start for several hours. The fuel rail has pressure (at least at the check valve) and I'm getting fire at the plugs. I've done the basic tuneup (plugs, distributor cap, wires, rotor bug), swapped out the coil, changed the fuel pump, and cleaned up the throttle body. I'm kind of at a loss here for the next steps.
A further note on the history of the vehicle. The previous owner was an older gentleman that lived on a farm. His kids put him in a nursing home and sold all of his stuff. This truck has sat outside a lot in a very dirty environment. You should have seen the 1/4" of gunk I cleaned out of the throttle body yesterday (yuck).
Old 12-16-2012, 11:18 PM
mdb mdb is offline
Update:
I borrowed a Fuel Pressure tester from the FLAPS. When I hooked it up and turned the ignition on it would initially pump up to about 50 psi but would not start. When I tried to get it to pump some fuel out it would only pump a small amount. Could that be a faulty ASD? ...or maybe the dreaded Crankshaft Position Sensor I've been reading about.
Old 12-18-2012, 05:20 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Switch around the relays in the PDC and see if she acts up when warm.
Old 12-18-2012, 08:58 PM
mdb mdb is offline
thanks,
If it's still acting up after after we get the CPS changed we'll try that.
Old 12-24-2012, 07:09 PM
mdb mdb is offline
Saturday my son and I got the bolts back in the CPS. They should make the engineer that designed that sensor and its location change a few out. ...and I let it run for a little while. It died again after about 20 minutes.
I also replaced the ASD with a new one. That didn't help at all.
I give up... I took it over to the dodge dealership on Saturday afternoon. They were supposed to troubleshoot it and call me back on Monday (today). I haven't heard from them yet.
Old 12-25-2012, 01:23 AM
panhead's Avatar
Rep:103
The thing about the CPS is its an old engine design, back from the 60's. Hence why the 318's and 360's aren't around.
If the fuel presure doesn't hold above 40 psi for 5 minutes, then its a bad fuel regulator. If you still have the original O2 sensors installed, that could of been the problem. With my dad's old 94 Dakota, once the engine reached operating temp., it would stall. Came to find out it was a bad CPS. We replaced a whole bunch of sensors, and you have to start somewhere. A lot cheeper than going to the dealer to diagnose it.
Old 12-28-2012, 10:43 AM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Did you remove the throttle and clean out idle air control. I have seen these seize in there. There are 2 bolts holding it on and you can remove it to clean it up good. Don't see it being the no start problem but I have seen them make that vacuum. Leak noise and stalling you described. Our other truck was doing this and we removed the iac and cleaned it up good and made sure it would move in and out and haven't had that problem again. Just make sure it doesn't come all the way out because you might loose the spring.
Old 12-28-2012, 07:06 PM
1999ram 1999ram is offline
Vehicle: 19999 dodge ram
1999ram is on a distinguished road
I was thinking it would be the idle control , thats what happen to me and since you discrived the inviroment the truck was in , it`s cheap enough clean or replace.
