Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 12-31-2012, 07:56 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
Good Choice. Frams are CRAP FILTERS.
Old 12-31-2012, 11:58 PM
Tivs Tivs is offline
Vehicle: 1997 Ram 2500
Color: Brown
Tivs is on a distinguished road
ya wix all the way. Anyone run hotshots in these motors to clean em out? i did some motor flush b4 my oil change but i just checked my oil and it looks like crap already. i its designed for diesels but says is safe for gas motors.
Old 01-01-2013, 01:57 AM
Vehicle: 1996 SLT
I don't think flushes are a good thing. I believe in doing frequent changes if the oil is crappy. When I was a kid in the 60s. A guy I know took diesel & oil mix to flush out an engine & washed the bearings out. Most flushes are just exactly that.
So be careful with that stuff. Seafoam is crap. I tried it once & it melted a Cat & plugged it up.
Old 01-02-2013, 12:15 AM
Color: Brown
ya ive used ATF on my play toys worked great. brake fluid is a little too powerful. im a believer in a clean engine inside and out. my powerstroke with 329K miles ran like crap tell i did my magic, wouldnt start in 80 degree weather it cuz the poppet valves were so gunked up. 2 hits with hot shots and 2 oil changes in a 2 week period running 5w20 on the second run that thing started in 20 degrees like nothing and 5000 miles later the oil still look brand new. during the cleaning u wouldnt believe the gunk coming out and the oil filters.....nasty. Check their site out, hotshotsecret...good stuff. for gassers replace on quart with half the bottle and run it for 2 weeks then change ur oil and filter.
Old 01-02-2013, 06:07 PM
Vehicle: 1996 SLT
I like ATF myself also. I checked out their webpage it seems geared towards diesels not gas rigs. There are a few companies out there with some good products. But I again look at price as a factor. Is it really worth it vs other options.
I have only found one oil additive that ever really impressed me. It was a product called IXL I believe. I have some in my stock of oils. On Ford Rangers with the Mazda 5 speed transmissions they used ATF. The fluid would burn black after time. Also the transfer case oils would burn. Most people never change the oils & failure happened. Well I tried this additive like 2-3 oz in the tranny & the same for transfer case. I bought my Ranger new in 1990. After about 35,000 miles I started seeing the fluid changing color to burnt. So I changed it & added some of this additive. I ran both that tranny & transfer case over 100,000 miles & the fluid looked as red & clean as the day I put it in.
Another product I run & like is LubeGard for trannys. It saved me a 4L60E trans, once. It drops ATF temps by up to 40 degrees on hard pulls with heavy loads. A tranny shop in Cottonwood Arizona did some test on I-17 between Camp Verde & the Prescott turn off. Can't think of the name of the grade. Old age setting in. The owner told me with 10,000# behind an automatic transmission he pulled the grade recorded the trans temps. Then went back & added LubeGard. He saw up to a 40 degree drop in trans temp. This was on a rebuilt trans he built. The outside temp ranged from 95 degrees down to 87 @ top of pass
