Old 12-16-2012, 04:52 PM
dukhunter88 dukhunter88 is offline
Vehicle: 2012 dodge ram 1500 quad cab
dukhunter88 is on a distinguished road
Default lowering kit
ok guys im wanting to lower my truck i want to order a 2/4 drop. On e bay they have the kit that just comes with the springs for $300. do i need the kit from maguahgys or am i ok just ordering the springs?
Old 12-16-2012, 05:03 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I eventually want to do a 2/4 drop also. From what I've read from the people on here you can go with a drop with either springs front and rear, or go front spindle/ rear springs. You might want to look into a track relocation bar also in order to keep the rear centred.
The all spring route is cheaper, but you would have a factory ride up front with spindles.
I'm sure someone that has dropped theirs will answer in on this as well.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 12-16-2012, 05:10 PM
Asur Asur is offline
Vehicle: .
Rep:4373
You might want to check the complete builds of Unbroken and Indeepwaterblue. They can probably give you a ton of info also
http://www.ramforumz.com/showpost.ph...7&postcount=20
http://www.ramforumz.com/showpost.ph...67&postcount=1
Old 12-16-2012, 11:10 PM
Stuck2theAxles's Avatar
Stuck2theAxles Stuck2theAxles is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT BigHorn
Color: Gray
Rep:108
Stuck2theAxles will become famous soon enoughStuck2theAxles will become famous soon enough
The Mcgaughys kit is pretty awesome i have their parts on both of my trucks even my 4wd and they are top notch they are the only ones that offer a progressive spring for the rear so you dont loose payload capacity here are pics of what they look like installed
2011 Sport 2WD 2/4 McGaughys "spring kit" not spindle with 1/2 coil cut out of the front with stock 20s with 275/55/20 Nitto 420s
2012 4WD bighorn with just the progessive 2.5 inch rear drop, stock in the front 22s with 305/45/22
Hope this helps
2011 CCSB Sport 2WD - McGaughys, FOOSE , shaved clean and newly added DIABLO SPORT !!
2012 CCSB Lone Star 4WD - McGaughys , KMC, shaved clean
2012 CC 2500 Cummins - Thuren, Fox , H&S w deletes upstairs and down
Old 12-18-2012, 11:00 AM
Ripper's Avatar
Ripper Ripper is offline
Vehicle: 2012 Ram CCab
Color: Mineral Gray
Rep:33
Ripper is on a distinguished road
Both sit PERFECT
Love the stance of the 2011
