No heat and no blower motor - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-16-2012, 07:29 PM
gwiz37 gwiz37 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLE
gwiz37 is on a distinguished road
Default No heat and no blower motor
I have 2002 Ram 1500 4.7L. I know of the relay switch needing to be replaced. I currently only have High on the blower.
My main issue is the heater. The heat is warm for about 3 seconds and that is it. I see no leaks and I have replaced the thermostat. Any help I can get is much appreciated.
Old 12-17-2012, 03:54 PM
Resident Technician
Rep:1915
I'm not sure what you're calling a 'relay switch" but the first thing you need is a blower motor resistor and possibly a new pigtail connector. As for the heat itself, the 4.7 is notorious for trapping air and causing problems like this. Have you had to add any coolant recently?
Old 01-11-2013, 08:18 PM
Trim Level: SLE
I could be using the wrong terminology, for that i do apologize. What I was refering to on the "relay" is under the dash. The blower motor itself works fine but I only have a the high setting on the fan and the anti-freeze is full.
Where is the blower motor resistor and pigtail. Where is that located at?
Again any help is greatly appreciated.
Old 07-03-2013, 08:30 PM
tipoblanco tipoblanco is offline
Vehicle: 2002 dodge ram
Color: blue
tipoblanco is on a distinguished road
i have a similar problem,started with the resistor burned out,was buried in leaves and years of gunk on my 2002 ram,i changed both the blower motor and resistor together,all speeds worked fine for about 6 months,then it would run for 1 minute and quit,set for 10 minutes and do the same thing,then just stopped working,i have another ram so i swapped the parts over to my other truck they worked flawlessly,i looked at rock auto parts and found there is a blower motor relay for it,has a picture of it but i cannot locate it and can find no fuse in the box for the blower motor either,any help would be greatly appreciated
Old 07-04-2013, 01:45 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The blower motor resistor is located on the passenger's side of the floor and can be hit easily with their left toe.
It's held in with 2-7 or 8mm screws.
blower motor, heater, heater fan, heater problem, heating
