AC fan motor stays on! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-08-2013, 12:16 PM
Martyman Martyman is offline
Vehicle: 2004 Dodge Ram
Rep:22
Martyman is on a distinguished road
Unhappy AC fan motor stays on!
I have a 2004 Ram and the AC blower fan motor stays on all the time even when I shut off the truck and pull the keys. Any idea's? I have no idea what to do except to start pulling out the cash that I don't have right now. Any help would be great.
Old 07-18-2013, 01:21 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
This is the first gen section, but I'll venture that the fan/thermal relay under the dash is bad. There's is actually another name for it but I can't think of it right now.
Old 07-29-2013, 12:45 PM
Rep:22
Default Fan/thermal relay.
You think that would make the fan stay on? I just had to replace my battery because it came on by itself I guess and it wiped out the battery over the weekend.
Old 07-29-2013, 07:59 PM
Vehicle: 95
Rep:1776
It could be the problem or an early indication of a bad FCM.
I'm willing to venture the guess is the relay and it's staying on, or kicking back on once the vehicle warms up. Did you have the air on when you shut it off?
Just a note. Even though this is posted under the 1st gen section, I'm going off your info as an '04 Ram. Is that correct?
Old 07-29-2013, 08:55 PM
Rep:22
Default AC fan
Yes, it is a 2004. Actually as of last year sometime when I would try to shut off the fan it would never go all the way off. It acted as if it was just on low speed but now it doesn't matter if it is on high or low. I pull the keys and get out and it is still on. To make it sound even more strange, it will be off when I leave it and I get back in the truck later to leave after I made sure it went off and it will be back on. I have read in other forums that it could possibly be the ignition switch. What do you think? P.S. What's an FCM?
Old 08-01-2013, 10:43 AM
Rep:22
I figured out the problem. The electronic part of the ignition switch is under the steering cowl on the left hand side/blinker side. I had to disconnect the tilt mechanism and the actual part had 2 screws in it but 3 different types of catch pins on it. Thank god for my patience or I could have jerked the thing out and caused a buttload of problems. Two of the pins in the part pretty burnt which it was a relief that I had the right part. If anybody ever needs the part# its Mopar 56045112AE. Everything is working fine now.
air conditionor, electrical issues, fan motor
