2003 cummins wont start. any suggestions? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-16-2012, 09:58 PM
farmall farmall is offline
Vehicle: 2003 3500 QC diesel
Color: Patriot blue
farmall is on a distinguished road
Default 2003 cummins wont start. any suggestions?
Hello all. My truck has been a little hard to start recently but only at times. I was thinking it might have been more related to the colder weather but I don't think that is the case now. Today, I went out to start it and it didn't start after about 10 seconds of spinning. I waited a few seconds and tried again. I think it started after 4 attempts. I just moved it in the driveway, only running for about a minute. I went to hook up a trailer this evening and it would not start. While waiting between attmpts, I could hear a pump running somewhere around the fuel filter. It seems to run a little longer than I expect but cuts off after about 10 seconds or so. I rolled it in the gargage where there was a fire going and after about 4 hours in 70 degree heat, it still will not start. It turns over but acts like it is not getting any fuel. Just in case you wanted to ask, it does have 3/4 tank. I just filled it yesterday. I really need some help because, right now, my dads powerstroke is hooked to my work trailer and I have to drive it until I get mine fixed. HELP!
Old 12-17-2012, 12:11 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
It could be a number of different things. If you have any aftermarket electronics installed, check the connections or remove them. You could have a failing lift pump (originally installed on the back of the fuel filter housing, and later retrofitted to an in-tank unit). A faulty rail pressure sensor could also keep the truck from starting. Have you changed your fuel filter?
07 rclb cummins. Efi live by silver bullet tuning
Old 12-19-2012, 10:29 PM
Color: Patriot blue
there is no aftermarket stuff on it. The fuel filter has about 15000 miles on it. I am thinking it could be that pump. It seemed to run a lot longer than normal.
Thanks
Old 12-19-2012, 11:16 PM
skinnysfd's Avatar
skinnysfd skinnysfd is offline
Vehicle: 2012 dodge ram 2500
Trim Level: big horn
Rep:53
skinnysfd will become famous soon enough
Try changing the filter first and then retry it. if that doesnt work my guess is your lift pump is bad. how many miles are on the truck? if it is the lift pump i would strongly suggest getting a FASS kit
2012 RAM 2500 HEMI AFE CAI flowmaster dual exhaust,airlift 5000 bags w/onboard compressor,shaved tailgate,2.5" lift/level tuftruck front springs,bushwacker pocket flares,gear alloy wheels, goodyear duratracs 315/70/17,bd gt hemiplus tuner much more coming
04.5,2006 5.9l cummins
Old 12-20-2012, 06:53 AM
Color: Patriot blue
215,000. What is a FASS kit? what is the advantage? where can I get one? i have never heard of that.
Old 12-20-2012, 08:03 AM
skinnysfd's Avatar
Rep:53
I'm gonna bet its ur lift pump then and a fass kit is more or less a fuel water seperation kit and lift pump as well go to fass.com and u can look em up. What it does is mounts on your frame rail and acts as a fuel pump giving anywhere from 95 gpm up to 150 gpm depending on which kit u buy. I'll try and find some pics of my old ones. I run it on all my diesels . Another benefit of it is it will allow clean fuel to your rail so it will also help save your injectors. Most diesel shops have em also u can look at an air dog ( same thing different co.)
Old 12-20-2012, 08:10 AM
skinnysfd's Avatar
Rep:53
fassride.com would be where u can get all ur info from em pm me and I'll tell ya where I got mine and get ya a number or check on the site there may be a couple vendors on here
Old 12-20-2012, 08:19 AM
skinnysfd's Avatar
Rep:53
benefits to the fass is also better mpg,easier starting,and a little bit more power as well. i always ran the fass platinum as well so i only had on filter to worry about and from what i was told the bigger kits are good for 550 plus hp and for sled pulling. i love the ones we run and have been problem free. instalation only took about two hours as well .hope this helps ya. oh and another thing is they are priced about the same as ur factory lift pump as well
Old 12-20-2012, 08:29 PM
skinnysfd's Avatar
Rep:53
www.fassride.com/
www.thoroughbreddiesel.com/fass/fuel-systems.htm
www.alligatorperformance.com › FASS Fuel Systems
heres a couple links for ya on guys i have dealt with and they are very good and knowledgeable
Old 12-21-2012, 01:06 PM
Sandman686 Sandman686 is offline
Vehicle: 2012 Dodge Ram 1500
Color: Mineral Gray Metallic
Sandman686 is on a distinguished road
On my 2003 Cummins my factory lift pump went out at 85,000 miles. The truck would only run for a couple of seconds and then die. I installed a FASS lift pump with new hose for around $450.00. My truck really ran great with the new FASS pump and the added fuel pressure. Good luck with everyting!
