Old 12-16-2012, 11:33 PM
cwnst2 cwnst2 is offline
Vehicle: 2002 Ram 1500
Color: Tan
cwnst2 is on a distinguished road
Default 2 problems...speedometer and tail lights
Two issues with a 02 Ram 1500
1) My Speedometer does not work, also my brake light and abs dash lights are on. my check engine light was on but after some research i saw that it possibly could be the speed sensor on the rear diff. I replaced the sensor and reset my codes and the check engine light turned off. I have driven approx 20 miles and the check engine light has yet to come back on. but my speedometer is not working along with the two lights that are lit up.
2) My rear running lights/ parking lights are not working. my headlights, reverse lights, signal lights and cargo lights all work it is just my running lights do not work. i checked fuses and none are blown. although all my fuses are getting full connection which was are 13.00... when reading the fuses for my tail lights i was getting a reading of .13-.15. which obviously is not sufficient.
Any help would be amazing... i am considering looking for a fuse box possibly to replace the one i have it is just going to be very costly and a pain
Thank you
Old 12-17-2012, 12:14 PM
Rep:1845
The light problem could very well be a defunct Front Control Module (FCM). Do you have any ABS codes stored at this time?
Old 12-17-2012, 02:05 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
most of the time its a software issue ... have your dealer check the software.
Smile even if its a little creepy
Old 12-19-2012, 01:33 AM
Color: Tan
i do not have any codes stored, i am going to take it to a garage to get figured out. Thank you RamTech and 06PowerWagon for the help
Old 08-01-2013, 12:21 PM
leroysimonson leroysimonson is offline
Vehicle: 1991
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
leroysimonson is on a distinguished road
I bought a used 91 cargo van and it certainly had many of the same problems, brake lights not working, speedometer not working, and blowing fuses. I doubt you would have the same problem, but I found that the previous owner had drilled a home through the wire bundle going to the back when he installed a partition behind the seats. If your vehicle has had any modifications to it, I would look those over carefully.
