Old 01-23-2013, 01:12 PM
Rep:1885
Originally Posted by B1500ram View Post
alright guys, thanks for all advice. NAPA told me that the O2 sensor, or any sensor for that matter would flash a code.
There's a reason these guys sell parts instead of troubleshooting and replacing faulty ones...
Old 01-25-2013, 05:53 AM
buzzvoodoo buzzvoodoo is offline
Vehicle: 2002 quad cab 4.7L
Trim Level: Quad cab
Color: yellow
Rep:13
buzzvoodoo is on a distinguished road
When was the last time you put new spark plugs in it? Pull a few of the spark plugs and see if they are toasted or not. spark plugs are cheap to replace so I would go with that option. Also maybe you have a dirty or clogged fuel injector. Run sea foam into her and see if that helps.
This might sound odd but start your car. put it into drive. and start accelerating at a moderate pace to quick pace. COUNT the times your vehicle shifts gears and make sure it goes into all gears. I took my truck to washington DC. Cruised control the hole way. I stopped for gas. got back onto the highway and got up to my 65 Miles per hour speed but noticed that the RPM's where HIGH as heck. I turned on the Cruise control and the car continued to stay in 3rd gear. I pulled over and turned the car off. turned the car back on and accelerated up to 65 but this time she finally went into 4th gear. That was the only time it ever happened but it did happen. make sure your truck is shifting into all gears fine.
Another side story. My old 2000 Mustang began getting horrible 7MPG fule economy like yours. I took it to pep boys and they told me my car had a dirty fuel injector. They literally ran 5 fuel injector cleaner treatments into the car and it solved my issue. It was a very cheap fix that solved the problem for another 40K miles until the car got totaled .
Old 02-21-2013, 01:26 PM
B1500ram B1500ram is offline
Vehicle: 2003 Ram 1500 4x4
Trim Level: Quad cab/SLT
Color: Atlantic Blue
B1500ram is on a distinguished road
sorry for the delay as i have been out of town, i did replace the upstream 02 sensor, ran for about 100 miles, then checked mpg. It is still around 10.5 mpg. I have not replaced spark plugs for a while, and i am sure that needs to be done, as well as TB cleaning. I will have to keep trouble shooting the issue and maybe repalce more of the sensors that Ramtech advised upon. As of now, i am still stumped... BUT....
Thanks again for all your help and the support of this forum!
Old 02-21-2013, 06:01 PM
dodgeacosta dodgeacosta is offline
Vehicle: 2003 dodge ram 1500
Trim Level: SLT Sport
dodgeacosta is on a distinguished road
clean the throttle body and check the up stream O2 sensor had same problem and that fix my issue
