Gas tank ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-17-2012, 09:01 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:224
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
Default Gas tank ?
I have a 09 sport CC with a 26g tank and would like to switch it to the 32g tank. Is this something that can be done with out to much work? Has anyone done this?
Thanks.
Old 11-02-2013, 03:38 PM
AKsteven AKsteven is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: TRX4
Color: Blue
Rep:35
AKsteven is on a distinguished road
I don't have an answer for you, sorry! But I'll be keeping an eye on this post. My 26 gallon tank has been bothering the hell out of me! Good luck
Old 11-02-2013, 03:42 PM
Grubrunner's Avatar
Rep:3883
I believe it's a straight swap.
I'm sure it's been discussed once or twice B4.
A search will yield results.
Good luck.
Grub out!
Old 11-02-2013, 04:18 PM
Rep:2929
The biggest thing would be the fuel pump
you would want to find out if both tanks use the same pump model
same goes for whatever they use for a float, (gas level indicator)
if both of them are the same, you have just saved a ton of money
the two different tanks use different hangers
so you will have to get the tank & hangers at a minimum
i believe that there is also a shield between the tank & the drive shaft, although it has been a while since i was under there
big tank, rear view
i don't have a side shot
