Old 12-18-2012, 09:26 PM
zipperhead zipperhead is offline
Vehicle: 07 ram 1500 5.7
Trim Level: BigHorn slt
Color: Inferno red
zipperhead is on a distinguished road
Default catch can,bypass,filter????
after sean at hemifever tuned my truck he said i will want to look into a catch can. i have noticed on the forums everyone is saying the 07 hemi has a internal pcv. so how do i go about doing this? my idea was just to take the hose coming off the oil fill and put a small breather on it, wile caping the inlet on my cai. will this idea work? if not what should i do. Also at 21k when i pulled the stock intake to install my cai my throttle body was a clean as could be.
Old 12-19-2012, 12:19 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
yep the suggestion of adding a breather filter to the crankcase hose is the option to do.
Old 12-19-2012, 01:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm not real familiar with that pcv system on that engine, but that doesn't sound like it's the pcv valve. I have also always heard the pcv is internal on 3rd gen hemi's. Which makes me wonder how you change the valve...
Sean
Old 12-23-2012, 02:17 PM
Color: Inferno red
ty satin ill have to get up to an autozone and see what kind of goodies i can find to plug the cai, thinking a rubber carb plug or something should do the trick
Old 12-24-2012, 03:49 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Get a good K&N breather not the little ones I see most of the time and plug the CAI. Check and clean your PCV valve every other oil change also. Good luck.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
