What would I need. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-18-2012, 10:30 PM
FOZMAN11 FOZMAN11 is offline
Vehicle: 2011 Ram
Color: Hunter Green
FOZMAN11 is on a distinguished road
Default What would I need.
Tried searching for 3 days and did not find my answer. Looking at a 20 X 9 rim with a offset of +12. The tire size will be 305/55/20, OD is 33.4". What will I have to do to get these to fit with no rub. Will it fit stock, just a level in the front, or full on lift. I do not like the rake my 2011 Ram 1500 has, so I'm looking to level. If the 20 X 9 rims won't work how about a 20 X 10 rim with a -24 offset.
Old 12-19-2012, 04:32 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Level the front out and you should be just fine.
The +12 will give you the 1/4 of clearance you need to fit the 305's.
The 20x10 -24mm wheels will stick out about 2" further than the stock wheels (outter rim edge). Just for reference.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 12-20-2012, 09:21 PM
Vehicle: 2011 Ram
Color: Hunter Green
Ok. If I would go with the 20X10 -24mm offset wheel, would it fit with just a level and the tire size referenced above. How about a stock truck with no level, would they fit? Could I run the 20 x 9 +12mm on a stock truck? How much tire will be sticking out of my fenders with both set-ups?
I know I threw out a lot of questions, but I'm trying to come up with a game plan on what is needed first. I would just hate to spend the cash on tires and rims, then not be able to use them.
Old 12-21-2012, 04:31 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:80
If you look at the pics in my profile they should give you an idea of how the wheels will fit. The wheels pictured are 20x9 -12mm offset with 35x12.5x20's.
If you go with the 20x9 +12's they will sit inward 1" (from where mine are in the pic). If you go with the 20x10 -24 they will sit out 1" further then where mine sat.
As far as tthe level kit vs no level kit? I can's say for sure because I had a 4" lift with that set-up. The 20x9 +12 ie believe will fit with a level or without, the 20x10 might be tricky.
Old 12-21-2012, 10:22 AM
Vehicle: 2011 Ram
Color: Hunter Green
Ok. Thanks for the info. I am understanding what is needed, just don't know which look I want. Still on fence.
Old 12-21-2012, 07:48 PM
LoneWolfNY's Avatar
LoneWolfNY LoneWolfNY is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
LoneWolfNY is on a distinguished road
If he went with a 20x10 -12 does that mean it would stick out 1/2" on both sides over stock?
Trinity, 180 Tstat, Magnaflow 18" muff no resonators, S&B CAI w/scoop, Bilstein 5100 Series Shocks all around, Billet Tech Oil Catch Can, AVS Vents, De-badged
Old 12-22-2012, 11:12 AM
Mikeaob's Avatar
Mikeaob Mikeaob is offline
Vehicle: 2012 Ram Express
Mikeaob is on a distinguished road
This is a 2wd with a 2 inch level 305/55/20 and 20x9 wheels with a 0 offset... No rub at all
Old 12-26-2012, 06:50 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I had Xeon ltz 305/55 And the rubbed the sway bar on hard turns the level makes no difference. I leved it and I now have 20x9 +13 and still rubbed the sway bar at lock. A 0 Would be best but a plus 6 should clear. I ended up swapping for duratrac 285/60's. If you want a 305/55 just do a level with 0 offset there will be no rub and it will look great. There I'd plenty of room for a taller tire and even wider it is the wheel offset stock that makes it hit the sway bar and even a +13 Still have me rub. When I do the CST lift AMD 35x12.5's I plan on running at least a -12 or -24 next time.
Old 12-26-2012, 10:11 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:80
If he went with that wheel he would gain 18mm of inner clearance between the suspension and wheels and the outer position of the wheel will be moved out 44mm. The overall wheel would be 1" wider (about 26mm) but the mounting surface is offset (towards the inner wheel edge) 31mm (from the stock wheel).
In order to have a wheel that does what you are asking, you would need to have the same offset as the stock wheel (+19mm). A 20x10 +19 would add 1/2" to both sides.
Old 12-26-2012, 03:20 PM
LoneWolfNY's Avatar
Thanks for explaining
