Weekend - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-19-2012, 11:20 AM
RugbyRef's Avatar
RugbyRef RugbyRef is offline
Vehicle: 2012 Dodge Ram 2500 (CTD)
RugbyRef is on a distinguished road
Default Weekend
Okay folks...I'm going to commence the DPF/EGR delete and install the H&S Mini Maxx this weekend. I will attempt to video the process for future reference. Of course, I will submit a post-overhaul write-up of lessons learned during the teardown and install.
Cheers!
Tim
Old 12-19-2012, 11:23 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:65
gusman will become famous soon enough
Start early in the day. My egr delete was a b!tchhh. The two bolts that hold the cooler on wayy in the back are a b!tch to get to. Ended up using an impact, extension, universal joint, and socket to get to em. It was not fun (3rd gen so your 4th may have more room)... DPF delete just have an extra set of hands around to help with the trans crossmember drop and keep a floor jack under the dpf to let it down easy. New exhaust goes in like pie... Make sure you install your minimaxx first incase the upload doesn't work. Mine kept having problems, turned out to be a bad obdII block and hdmi cable, so bad that it crapped out half way through the upload and truck wouldnt start. H&S has the best customer service out of any company Ive ever dealt with for anything, so give them a call if you have any issues. Goodluck! It's a completely different truck when you're done!
Old 12-19-2012, 12:52 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
What are you doing as far as EGR delete? Valve, butterfly and cooler? What are you replacing them with? New intake horn? Just curious as to what parts you are going with.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 01-02-2013, 02:19 PM
RugbyRef's Avatar
DONE!! I did the following to the truck over the holidays:
- Removed the stock exhaust and replaced with custom exhaust straight pipe to a 4" end.
- Deleted the DPF.
- Removed the EGR system (the WHOLE system) and installed an EGR removal kit from Custom-Diesel.
- Installed an H&S Mini-Maxx with pyro and overdrive transmission software upgrade.
- Installed a Bak-Flip F1 cover on the back end of the truck.
- Tinted the front door windows.
I am a huge skeptic of claims made by people who say that one "snake-oil medicine" is better than another, but I will tell you from MY experience since these mods have been completed....WOW!!!
I immediately saw performance gains across the board in the truck. Although I have not dyno'd the truck yet (soon), I can just feel the throttle response has dramatically increased. The MPG as well - I am now averaging between 18 and 20 mpg. Took the truck on a trip over Christmas to Gatlinburg (from Cape Girardeau, MO) and got there on less than one tank...450 miles.
I did the complete removal and install myself. It's definitely not hard if you have the proper tools. I even did a write-up, with pics, on it because the illustrated instructions I got with the EGR delete kit from Custom-Diesel were for an older model Cummins engine...AND they were out of sequence.
The Bak-Flip F1 cover was installed in 30 minutes.
Hope this helps!
Tim
Old 01-02-2013, 11:29 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
That's great!
2012 Ram 2500 4x4 ST Crewcab, Cummins 6.7, RCX 5 inch lift, 22x12 Fuel Mavericks, 35 inch Toyo MT's, H&S XRT Programmer, MBRP exhaust
Old 01-03-2013, 08:30 AM
gusman's Avatar
Rep:65
Sickkk! Night and day with the deletes, not to mention straight pipe sound bada$$ in these 6.7s
Old 01-22-2013, 03:32 PM
kozzy kozzy is offline
Vehicle: 2016 Ram 3500 Big Horn
Color: Delmonico Red
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
kozzy is on a distinguished road
Do you have any pics? and how long did it take you?
I am thinking about the same mods, I have to check with the dealer about inspections issues first.
now Im great with tools and following instrucitons, is this a project that someone that knows how to use a wrench and follw directions can do easily?
Old 01-22-2013, 03:34 PM
Sorry, just posting this so I could subscribe to this thread
