United Radio
Old 12-19-2012, 04:24 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Send a message via Skype™ to adventurer
Default Head lights blinks when WOT ????
Head lights blinks once as if giving high beam when WOT under the speed of 40 miles on my 2010 hemi , any help please ?
2010- S&B CAI/87MM TB/HKS TB GW/OIL FILTER BREATHER/Y PIPE/PYPES VIOLATOR MUFFLER/HEMIFEVER TUNE.
06- MAGNAFLOW CAT-BACK/Y PIPE/TB SPACER/HKS-TB GW/MOPAR CAI/SUPERCHIPS/OIL BREATHER FILTER/JET 180 TSTAT/3.92 LSD
Old 12-19-2012, 04:40 PM
Rep:1824
I presume the lights are set to low beam when this happens. It's remotely possible something is binding up and causing a short to power on the high beam circuit.
Old 12-19-2012, 04:48 PM
adventurer's Avatar
So its not from the alternator as some workshops said, yes it happens when lights set to low beam and under the speed of 40 miles only , above that speed nothing happens !
Old 12-19-2012, 05:28 PM
Rep:1824
If they can explain how the alternator can energize one headlight circuit and not the other, I might give that some consideration. I would want to connect a volt meter to the headlight circuit and see if voltage is present on that circuit when it happens. Now that I think about it, I wonder if a loose low beam filament could be contacting the high beam filament under acceleration and causing this. Try a different bulb or switch the bulbs from side to side and see what happens.
Old 12-19-2012, 05:53 PM
adventurer's Avatar
thanks ram tech
Old 12-19-2012, 07:41 PM
Rep:1824
Ok, after looking the wiring diagram over, I'm thinking this about has to be a TIPM problem. The odds of both high beam circuits energizing from a short to power seem pretty slim.
Old 12-20-2012, 09:27 AM
adventurer's Avatar
I noticed today that the dashboard lights are doing the same , checked the battery it was not good so i replaced it with bosh battery 740 cc and 80 ah (with the new battery it gave me different readings than it use to give like fuel consumption and the DTE) , checked the alternator it is good but still having same issue !
Old 12-20-2012, 10:32 AM
Rep:1824
Well, the dash lights obviously don't have high beams, so at this point, it seems like either power is dropping off or you're losing a ground.
Old 12-20-2012, 01:18 PM
adventurer's Avatar
I found someone else on other forum his truck doing the same when traction control kicks in , i didn't pay attention for this on my truck but i think it does that when TC kicks in ( i ll pay attention for this at night ) , So if this is the case is it normal or something wrong ?
