Old 12-20-2012, 02:37 PM
Beauhymel Beauhymel is offline
Vehicle: 1996 Dodge Ram 1500
Beauhymel is on a distinguished road
Default Dodge transmission compatibility
I need to know if a transmission form a 1999 Durango with a 5.9 would work in a 1996 Ram 1500 with a 5.9. I also need to know if I will also need the computer from the Durango. THANKS in advance!
Old 12-20-2012, 03:00 PM
Rep:1845
They most likely will, but without knowing for sure which transmission each one has, I can't say for sure. If you would like to compare part numbers on the two, here is an illustration that shows the location.
Old 12-20-2012, 03:31 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Both 5.9, should both have the 46RE, meaning straight swap. Should not need to swap computer.
Old 12-20-2012, 03:32 PM
All the research that I have done indicates that both have a 46RE. Mostly would like to know if the trans computer changed much between 1996 and 1999. Thanks again.
