Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 12-20-2012, 05:43 PM
GaryV GaryV is offline
Vehicle: 1994 Dodge Ram 2500 V10
Color: Burgandy
GaryV is on a distinguished road
Default 1994 Dodge Ram 2500 V10 no heat
I have a 1994 Ram 2500, V10, the engine runs great, but I can not get any heat.
1. Flushed the entire system with the thermostat removed.
2. Replaced the thermostat
3. Blower motor works as suspossed to
The engine gets hot and the dash indicator works, but I can not get any heat to the cab. I am at my ropes end any suggestions would be greatly appreciated.
Gary V.
Old 12-20-2012, 05:53 PM
Rep:1877
Flushing is no guarantee of clearing out a stopped up core, so this could be the problem. Are the heater hoses hot and are you sure you don't have any air trapped in the system anywhere? If one of these isn't the problem, you're probably looking at a blend door problem.
Old 12-23-2012, 05:23 AM
Tivs Tivs is offline
Vehicle: 1997 Ram 2500
Color: Brown
Tivs is on a distinguished road
Did it just stop? or did u just purchase the truck. If u just purchased it maybe someone did a ball valve mod...hell if uve owned it and it just stopped ive seen the ball valve clog up acting like its closed causing no heat.
Old 12-26-2012, 09:23 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
Smile
Tivs, where is this ball valve? I was going to suggest checking to see if both heater hoses where hot. If so a possible blend door not working. I don't know if they are vacuum, but mine must be because it is all knobs no sliders.
Old 12-28-2012, 11:03 PM
Color: Brown
A ball valve mod isnt factory hints the word mod but to do it u put a ball valve on ur return or supply or both to the heater core. its useful for colder ac and if the core goes out u don't have to dump gallons of coolent
Old 12-31-2012, 09:00 PM
Vehicle: 1996 SLT
OK, that make sense. I thought you were talking about something factory.
Old 01-01-2013, 01:03 AM
Color: Brown
i kno chrystler did a similar set up on some models of vehicles with a vaccum actuated valve.
Old 01-01-2013, 02:49 AM
Vehicle: 1996 SLT
Smile
Yea back in the 70s & I think early 80s. At least my 88 D250 didn't have that.
