Old 12-20-2012, 05:34 PM
jflare jflare is offline
Vehicle: 2012 dodge ram 1500 express
Trim Level: express
jflare is on a distinguished road
Default mygig navigation
hello, i have a 2012 dodge ram express, i want to upgrade to the mygig navigation. now would this be a plug and play kinda deal or would i have purchase something special to hook up to it for the navigation to work?
also on that note i currently have a mygig system that i bought from ebay without the navigation but im curious as to why when i start up the vehicle it shows the chrysler logo and in the background of the menu has a chrysler logo when i had plugged it up in my nitro to see if it would work and it showed a dodge logo in that vehicle
Old 02-19-2013, 03:21 PM
CORAMGUY's Avatar
CORAMGUY CORAMGUY is offline
Vehicle: 2011 Dodge Ram 2500 LB
CORAMGUY is on a distinguished road
Have you gotten this sorted out?
I just installed a MyGig nav head unit, dual microphone dimming mirror and backup camera in my 2011 2500. The install would be about the same. If you haven't figured it all out yet, my recent experience may be helpfull...
Old 02-19-2013, 05:25 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
The 430N (navigation radio is plan and simple swap. As long as the radio was made after 2008/2009. Earlier mygigs and accompanying vehicles has the GPS and Sirius antenna separate. Now the antennas are one. The other factor is, if the radio is built in 2011/2012 there may be a security code needed to unlock the radio (anti-theft feature). This can be undone by a FRIENDLY dealership. They may ask for proof of purchase before unlocking.
The logo on the startup splash screen is a tricky one... sort of... All the mygigs (although Chrysler stopped calling these mygigs, it has become a common name much like Kleenex and Windex) the 430, 430N and 730N all have the chrysler/dodge/ram/Fiat/VW logos within the software of the radio. The radio, upon start up communicates with the cann bus system on the vehicle (either checks the VIN, or other make/model identifiers) to display the correct logo. Now, it may take a few startups or even a computer flash by the dealership to get everything in sync, since its not 100% correct. I have personally seen a 430, 430N and 730N display other logos in my RAM when I swapped it out. After a few battery disconnects, it reset and all was fine.
I originally had the plan 130, upgraded to the 430 then a few weeks later, moved to the 430N, then to the 730N.
You may need to update the radio (the 430N (RHB)) software.
You can also find mygig info at http://mofv.com/mygig but this site is NOTORIOUS for being down.
I have started and contributed on a few forums on there on this very subject.
If I may suggest becoming a level 1, 2 or 4 supporter and skip the ads, the site speeds up a bit and get access to cool features and unlocked threads!! It is the best money I have spent!! HANDS DOWN!!
Old 02-24-2013, 08:05 PM
jamm999 jamm999 is offline
Vehicle: 2012 Dodge ram
Rep:12
jamm999 is on a distinguished road
Default 730n
Is there a way to tell if a radio head is older than 08 from the front? When looking at the back of them what does the combination antenna connector look like? Yellow or white? I'm looking for a 730 n for my 2012
Old 03-05-2013, 03:48 PM
Rep:126
From the front, no. RHR and RER are the 730N models, RER is before 2010-2011, RHR is 2011-2012. Both are cosmetically the same, but the circuitry inside and slight software changes are in the inside. RHB is the 430N model and share the same look as the 730N's except the sales code on the lower right side of the front of the radio and the Uconnect / load buttons are swapped from the 730N and 430N. The 430N the load buttons for CD/DVD are on the right, the 730N the same buttons are on the left side.
Both of the radios have the Olive green and white connectors. If I am not mistaken, the White is AM/FM, and the Green is GPS/Sirius
Also the 730N has 1 or 2 mini USB connectors on the back (although the connector is perspiratory a USB cable WILL connect and work if you stick in there (providing the USB connector is small enough to fit the cavity).
Old 03-05-2013, 04:34 PM
Rep:2657
Although the RER 730n was in the 2009 & 2010 Ram
It is fully compatible with the 2011/2012 Rams that came with the RHR 730n
Many times if you buy a HIGH SPEED CAN BUS MYGIG radio on places like eBay
You won't need to get the system flashed by the dealership, because it has already been installed in another vehicle
The 2009 - 2012 Ram all use the High Speed Canbus system
2008 & earlier had the LOW speed canbus system & won't work in the '09 - '12 Rams
The Base model of the 2009 - 2012 MYGIG radios is the
RES 130, there were 2 models of RES, one has the phone receiver icon, the other does Not
The next radio up is the RBZ 430, some but not many had the REN model
it does not have Navigation, but does have a touch screen
The RHB 430N is a touch screen radio with GARMIN navigation
The 2 730N RHR & RER are the top of the line radios, both use NAVTEQ navigation
both have everything inside the radios, no external Modules are needed for Bluetooth, USB, microphone, etc.
2 different websites that have quick reference manuals & full manuals in PDFile,
click the radio(s) described on the left of the page. The radio will pop up with a summary below it. If you look back at the left, you will see the word Downloads, click the Media Center & a full manual is online
http://www.dodge.com/en/owners/quality/rbz/
fill in your vehicles information & find which radios work with your vehicle
don't pay attention to the prices, you can find cheaper else where
http://www.oemautopartsco.com/
Old 03-05-2013, 04:56 PM
Rep:2657
Someone asked about the DEFAULT IMAGE on the screen
you can choose one already in Memory on the Hard Drive, or use your own picture
In the default mode, the vehicle brand logo is displayed
in the right half of the screen. Press the Menu hard-key on
the right side of the radio to access one of the Setting
menus.
It is recommended to change the picture dimensions on a
PC or Digital Camera to 240 by 158 pixels before the
import.
Old 03-17-2013, 09:41 AM
MTLRam007 MTLRam007 is offline
Vehicle: 2012 Dodge Ram CREW Sport
MTLRam007 is on a distinguished road
I just bought a 12 Ram sport. It has he base radio with uconnect Bluetooth option. What do I need to switch to a nav radio. My second question is which one is better the 430N or the 730N? Sorry to hijack your thread
2012 Ram 1500 CC sport, black on black leather, sunroof, 121L tank, 3.92, tow pkg, trailer brake control, uConnect
Mods so far: BakFlip F1, BakBox, AMP bed extender, DeeZee tailgate assist, Raptor 5" wheel to wheel
NEVER INSTALLED: Go Rhino steps ( was sent wrong ones and very flimsy
Old 03-20-2013, 02:00 PM
Rep:126
Well... On the issue of which one is better, the 430 or 730... Depends on who you ask and where you live in the US. The 430N and 730 BOTH use Navtech maps. BUT the 430N uses the Garmin graphics and GUI interface, whereas the 730N uses (I believe, if I am not mistaken) the navtech or Harmen Becker created GUI interface (not pretty and misses a lot of the options that the 430N offers in the NAV area). Although the 730N has (almost) realtime traffic conditions. So, if you use the Nav unit, the unit will detour you around the traffic (in theory).
I have had the 130, the 430, the 430N and currently the 730N. I like the 730N because it came with bluetooth and uconnect in unit because my 130 did not have the uconnect buttons/option.
I think you would like the 430N since you already have the uconnect module (430(N) radios need the uconnect module)
Old 03-21-2013, 07:16 PM
Thanks for the info but the auction I won on eBay was cancelled and the user is no longer registered Good thing I didn't pay him. Oh well I will get a chance one day. Thanks for your help
