Old 12-20-2012, 07:30 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
Default How to install torque converter
I bought a edge converter, and I'm getting quotes for 400 bucks install.. Is it easy to do
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 12-20-2012, 07:45 PM
bighemi04's Avatar
Rep:623
it may be easy but i would just pay someone, that way if something goes wrong, their labor is warrantied
Old 12-21-2012, 11:32 PM
Rep:79
Does anyone have a write up on a how to on our 545re trans to do a stall swap
Old 12-22-2012, 11:35 PM
HemiLonestar's Avatar
Rep:274
I followed the directions in the factory service manual for transmission removal (I've removed many transmissions before, but it was the first time on something this new). Since I had to replace the entire trans anyway, I decided to get a Circle D 2800.
Basically:
- Disconnect battery
- Set parking brake (unless you're going to be in the air)
- Remove driveshaft (or shafts if you are 4x4)
- Disconnect wiring from transmission and any wiring that is retained by the trans (my O2 sensor wiring is clipped to the top of it)
- Start unbolting, I started at the rear trans mount, then removed the crossmember
- Support trans with trans jack (these are INVALUABLE)
- Unbolt tie bar up front, this just bolted between the frame pieces, but it was in the way
- Unbolt girdle piece between engine and trans, this will allow you access to TC bolts
- Unbolt TC bolts
- Remove bellhousing bolts
- You will need a jack to support the engine itself since the trans mount usually does the rear supporting
- Here comes the fun part, you will need to wiggle the f*ck out of the trans to get it to come off the engine, you will end up doubting yourself and checking to see if you missed any bolts 12 times, just keep wiggling
- Once it's out, you can remove the TC, be careful it's heavy (full of fluid)
- Fill your new TC with fluid (you'll end up spilling some)
- Put new TC on to input shaft, you should feel 2 engagements, as the TC turns the input shaft AND the pump, make sure this goes all the way in like it's supposed to or you will regret it when you try to put it back in
- Reverse all steps, make sure you don't forget the stamped steel plate that goes between the engine and trans
- Once you're ready to start, set parking brake and shift engine to neutral, start engine and allow to warm up so you can check the fluid level (fluid check done while war, running and on level ground), top off fluid
- If you are able, reset transmission adaptives (not quick learn)
- Go for a drive
Now would also be a good time to put a nicer aftermarket pan on (with capacity and cooling fins) and maybe a bigger trans cooler if there is one for yours.
Some pics from my experience:
"Big Red"
2006 Charger R/T
Old 12-23-2012, 01:03 AM
Rep:79
Do I have to empty the trams before doing any of this
Old 12-23-2012, 01:14 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
not really might be easier if you dont want the mess and if you dont have a lift it blows lol
Old 12-23-2012, 06:10 PM
Rep:274
It will make it lighter, but otherwise no. Depending on how many miles you already have, this might be a good time for all new fluid and filters to go with that brand spanky new converter.
"Big Red"
2006 Charger R/T
Old 12-23-2012, 07:11 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
rep points for hemilonestar!!!
07 rclb cummins. Efi live by silver bullet tuning
Old 12-24-2012, 08:02 AM
InDeepWaterBlue's Avatar
Rep:611
I admit I paid someone to do mine lol I don't have an extra jack to support all that, and if something goes wrong a decent shop will warranty the work they do. I went to AAMCO here and they warrantied what they did for 5 years, add that on top of the manufacturers warranty and I'm a happy camper. Headers were one thing, but I'm not screwing with the trans. I hate to say it but Dodge does have a bad reputation for going through tranny's and I wasn't trying to jinx it.
Great write up on the install and definitely agree that's a good tie to upgrade and replace anything that needs to be done.
Old 12-24-2012, 02:58 PM
Rep:274
Oh yeah, TRANSMISSION JACK!! Couldn't have done it without it.
"Big Red"
2006 Charger R/T
