Old 12-21-2012, 12:19 AM
5.7Ram1500 5.7Ram1500 is offline
Vehicle: 2003 Dodge ram 1500 5.7 HEMI
Trim Level: Slt
5.7Ram1500 is on a distinguished road
Default Cylinder 4 misfire 5.7 hemi help
Check engine light on cylinder 4 misfire any suggestions?
My opinion from reading other forums is lifter fail ?
Thanks for your help
Old 12-21-2012, 09:31 AM
Rep:1845
Lifters are not known to fail in Hemi's, and I've personally never seen it happen. Valve springs are a different story up until the 2006 model year. Once you rule out a fuel or ignition problem, pull the valve cover and check the springs.
Old 12-21-2012, 11:59 AM
Trim Level: Slt
Default Misfire
Ok I'll check fuel and ignition systems first but alot of guys with this kind of misfire was caused by bad lifter any body have had this problem?
Old 12-30-2012, 11:11 PM
Hot Rods 4 Hogs Hot Rods 4 Hogs is offline
Vehicle: 2004 Dodge Ram
Trim Level: sl
Hot Rods 4 Hogs is on a distinguished road
Yes i have lifter keeper broke and lifter turned and ruined cam.pull your plugs and check to
to see if any are black.
