Old 12-21-2012, 01:58 PM
Red Grimm Red Grimm is offline
Vehicle: 1994 Dodge Ram 1500
Red Grimm is on a distinguished road
Default 94 Dodge Ram Fuel Pump
Hello again I have narrowed down my problem to a faulty fuel pump. I was informed that the easiest way is prop up the bed. My question is do any you have detailed instructions on tipping the bed? I have found there are a total of 6 bolts on a 6' bed and have a general idea of where each one is located. I am curious to know if I need to remove my rear bumper and hitch and where the tail-lamp harness hooks up. I do have a moveable engine hoist.
Old 12-21-2012, 02:05 PM
Rep:1909
At our shop, we don't remove the bumper, hitch or wiring. We tip up the beds and support them with a pole jack.
Old 12-21-2012, 03:02 PM
Thank you that makes it much more simplistic then.
Old 12-21-2012, 05:34 PM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
Trim Level: sport
major324 is on a distinguished road
what i did was i had my son help me and the only issue we had was the wire loom to the tail lamps were a bit snug and hard to separate and lastlu my body lift was a bit of a struggle to keep in line but other than that really easy compared to dropping a full gas tank and laying on my back to do it!
Old 12-21-2012, 07:54 PM
That's what I figured I have no body lift on my truck, however the harness for the tail lamps do look a little bit snug. I have located all six bolts even have access holes through the bottom of the frame which is nice. I just hope this fixes my problem I can hear the relays click on under the hood but fuel pump won't until I wrap on the tank with a hammer with it keyed on.
Old 12-21-2012, 08:54 PM
bassa2000 bassa2000 is offline
Vehicle: 1996 Dodge Ram 2500 4x4
Trim Level: club cab
Color: red
bassa2000 is on a distinguished road
Default Pump
What brand pump did you purchase? I have 118,000 on my 96 on the original pump and was thinking of replacing it just for preventive maintenance. Thanks
Old 12-22-2012, 10:34 PM
I went with an Airtex Master.
Old 12-23-2012, 09:44 AM
Color: red
Default Fuel pump
Thanks for the info.
Old 12-27-2012, 08:13 PM
Fuel pump went in works great!! thanks for all your help. Only issue is gauge reads 1/4 tank however I have used 10 out of 26 gallons. So I should be just over half tank. Will this issue fix itself when I fill?
94 ram, bed removal, fuel pump
