injector?? lift pump?? help..please.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-21-2012, 07:57 PM
deke rivers deke rivers is offline
Vehicle: 2004 dodge ram diesel
Trim Level: deluxe
Color: gray
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
deke rivers is on a distinguished road
Unhappy injector?? lift pump?? help..please..
i have a 2004.5..325 horse..the other day it lost power...lite came on code po 148..had it towed to dealer..right away they said its the injectors...cost $895 per injector..truck back in polebarn...i changed fuel filter and added diesel 911 just in case it had water in fuel..truck starts and runs good in idle..engine light not on now...could it be lift pump..how can you tell...is it fuel pump..if injector (s) can you just replace bad one or should you replace all...?? im sure someone out there has had same problem...read on internet that chances are its lift pump....help please...need all opinions...got to get back on road..truck only has 130000 miles on it...emailed cummins...no help...thanks...
