Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 12-22-2012, 05:14 AM
juicestain09 juicestain09 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Laramie Crew Cab 4X4
juicestain09 is on a distinguished road
Default U-Connect module replacement - self install or dealer?
I recently bought my 2009 Dodge Ram 1500 Laramie Crew Cab and it needs the U-Connect module replaced. I had my local Dodge dealership order the part for me, but I'm wondering if I can install it or if the dealership needs to. The part itself was expensive enough as it is, if I could get away from paying shop labour costs I'd be all for it. The reason I initially thought Dodge had to install it themselves was because the same sort of thing happened with my 2002 Pontiac Aztek and I had to get GM to install the part because they had to program it to my vehicle or something like that.
Does Dodge need to install it for me for this purpose, or can I install it myself? Looking at the replacement procedure, it's easy as pie so it would be nice if I could do it myself.
Thanks!
Old 12-22-2012, 10:53 AM
Rep:1890
You can do the install. I'm not sure off the top of my head if it will need to be programmed with the VIN or not. Even if it does, the dealer can do that for you regardless of who installs it.
Old 12-22-2012, 05:33 PM
Perfect. The hourly shop labour fees up here are crazy so that should save me about $300, even if they do have to program it.
So my next question then: does the same module that runs the u-connect run the overhead garage door opener buttons and the compass? I was told that by the dealer but I just want to make sure.
Old 12-22-2012, 05:39 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
That is a different module located in the overhead console and the Homelink buttons are part of that module. The u-connect module is located on the passenger side kick panel.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 12-22-2012, 06:32 PM
Rep:2657
You can install it yourself
the dealership may have to program it, but if it worked before, it may just be plug & play
look at the front of your radio, right lower corner next to the auxiliary plug
what are the 3 letters printed there
with the 2009 Laramie, i would guess RER 730n
but it may be something else, like RHR, RHB, RBZ, hopefully not the REN, RES
by the way, do you have the full floor console or not ?
Old 12-22-2012, 10:08 PM
I should've clarified myself. The compass is displayed in the cluster driver info center.
I have the bucket seats, not the full floor console. I'd have to check the stereo to confirm, but I believe you are correct that it is the RER 730N.
Old 12-23-2012, 01:36 AM
Rep:2657
i found this on a Jeep site, they use many of the same radios as the Rams do
i thought that, the RER 730N has a Uconnect module within the unit
but read for yourself, it came from this site, maybe you can figure it out
http://www.wkjeeps.com/Mygig_parts.htm#ABOUTPN
UConnect Hands Free Bluetooth - All versions of the MyGIG RER navigation radios feature UConnect built-in (a wiring harness is required for operation, see "Upgrading" section below). The non-navigation versions of the MyGIG radio (model REN) do not have UConnect built-in, but will interface with the factory UConnect system, if equipped. UConnect is the exclusive voice-activated, hands-free, in-vehicle communications system. It encourages safe vehicle operation and doesn't compromise driver control. UConnect allows you to dial your wireless phone through simple voice commands. In addition, UConnect mutes your radio before receiving or sending a call, allows you to store up to 32 names and four numbers per name (128 entries) in the system's phonebook, and is flexible enough for an entire family (up to five phones can be linked to the system). UConnect includes Bluetooth technology that enables your wireless phone to connect to your vehicle without wires or a docking station. This leading edge technology will allow you to store your wireless phone anywhere in the vehicle.
The UConnect™ system is fully integrated with the vehicle’s audio system. The radio display will be used for visual prompts from the UConnect™ system such as phone battery status, signal strength, caller ID, and call type. NOTE: Your phone may not support all available UConnect™ features. Refer to your vehicle owner’s manual for UConnect™ system operating instructions.
Good Luck
Old 12-23-2012, 01:39 AM
Rep:2657
how to take out your radio
Old 03-12-2013, 08:57 PM
ltdan ltdan is offline
Vehicle: 2009 Ram 1500
Trim Level: Lone Star
Color: Rugged Brown Metallic
Rep:36
ltdan is on a distinguished road
If you have the RER, there is no uconnect module. If the truck did not come with uconnect but you have the RER 730n (touch screen with nav), you just need either the auto dimming rear view mirror with the built in microphones, or a $35 dollar mic that plugs straight in the the back of the radio.
If you have a non Nav MyGig (430), it has the separate module. The install is easy, just figure out where it's located, remove and replace. I know it has to be programmed by the dealer with a Starscan tool if you did not originally have it, but I'm not sure about replacements.
Old 03-13-2013, 01:41 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Wow, another answered 3 month old posting. Not sure but the person most likely already has the answer they were looking for.
