Old 12-22-2012, 01:45 PM
15004x4's Avatar
15004x4 15004x4 is offline
Vehicle: '07 Ram 1500 QC 4x4
Rep:28
15004x4 is on a distinguished road
Default Bilstein cost question
I'm close to pulling the trigger on getting a set of 5100's to level out my 1500 4x4. Can I save any $ by buying them myself and having a shop install them or should I just let the shop order & install them? Also, could anyone in the SoCal area between LA and LBC recommend a shop to do the install and alignment? Thanks!!
Old 12-23-2012, 12:06 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Depends on labor rates at the shops in your area some shops will charge more if you supply the parts, some won't if you can find a good shop that charges the same rates for installing parts you supply vs parts they supply then yes you can save money if your looking for a full set of 4 (front and back) you can check them out here https://discountautoperformance.com/...7cc74ba018e3e3
Heres some info on them if you dont already have it.
Front Shocks
*Bilstein 5100 Series Ride Height Adjustable Shock Absorber
*Collapsed Length (IN): 15.18
*Extended Length (IN): 21.26
*Travel Length (IN): 6.08
*Lower Mount: Clevis
*Upper Mount: Stem
*Shaft Diameter: 14mm
*Reservoir: No
*Finish: Zinc plated
*Body Design: 46mm ID snap ring grooved body (Coilover)
*Internal Design: Mono tube
*Boot Included: No
Bilstein's 5100 Series Ride Height Adjustable Shocks are Zinc-plated shocks that install like factory replacement shocks and are designed to correct the factory nose-down rake, allowing for the use of larger wheels and tires. The OEM spring seat is repositioned to provide more preload to the factory spring. The result is a level front to rear ride height. Features include: Monotube gas pressure construction, Extremely affordable, Snap ring grooves on shock body provide up to 2.75" of front end lift (depending on application), More practical than strut extension or spring pre-load spacer kits, Offers increased wheel travel while accommodating a 33" tire, Application specific design available for many popular light trucks and SUVs.
Rear Shocks
*Bilstein 5100 Series Shock Absorber
*Collapsed Length (IN): 16.16
*Extended Length (IN): 26.14
*Travel Length (IN): 9.98
*Lower Mount: Eye 14.4mm
*Upper Mount: Eye 14.4mm
*Reservoir: No
*Body Design: 46mm ID smooth body (Non-coilover)
*Boot Included: Yes
Bilstein’s 5100 Series Shocks offer traditional Bilstein technology with applications for lifted trucks, Jeeps and prerunners. 5100 Series shocks feature Bilstein's superior single tube high gas pressure design for the upmost in consistent fade-free performance and long life. Features include:Monotube gas pressure construction, Self-Adjusting Deflecting Disc Valving, High-Flow Piston Reduces Harshness, Independent Rebound & Compression Tuning, Larger Working Piston Area for Exact Damping, Superior Control for Large Diameter Tires and Designed for specific manufacturer lift kits utilizing the stock O.E.M. mounting configuration.
Thanks
Jeremiah
Discount Auto Performance
