Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 12-22-2012, 10:27 PM
cummincents cummincents is offline
Vehicle: 1989 250 ram
Trim Level: le
Color: 2 tone blue
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
cummincents is on a distinguished road
Default lower my 89 250
Want to keep stock spring and travel in front, only 2" lower.
Want to keep rear travel and capacity as close to stock only 2" lower.
I am thinking lowered spindles for the front. Are these available for a 250?
The truck will be expected to work, and has the Cummings, so I think heavy duty is in order.
I'm not sure what is best for the rear. I really like the way the truck rides
but needs to be lower and still carry full payload. I pull a bobcat and trailer
through the hills. The truck will be required to work.
All help is appreciated.
Old 12-28-2012, 05:32 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Not sure about spindles for the front, but any competent suspension shop should be able to set you up with a lower, stronger set of leafs for the rear. You could always add some airbags in the rear to maintain load carrying ability.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 01-03-2013, 08:24 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Air bags are the eaiser but there spring shop that could build a set. there use to be a couple of trucks where the springs were mounted on top flipped them on to the bottom which gave better than 2".
