Not a Sway bar???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-23-2012, 11:07 AM
xtreme's Avatar
xtreme xtreme is offline
Color: Grey
Rep:29
xtreme is on a distinguished road
Default Not a Sway bar????
Ok so I know that my 2012 RCSB Express does not have a rear sway bar. I climbed underneath of it this morning and noticed the bar pictured below. Is this a replacement for a swaybar? Because it ties the axle to the frame but only in one point as opposed to two with the swaybar. Can I still install a sway bar? Any help would be great.
[/IMG]
Old 12-23-2012, 11:09 AM
xtreme's Avatar
Color: Grey
Rep:29
Old 12-23-2012, 12:01 PM
MOFOGO's Avatar
MOFOGO MOFOGO is online now
Vehicle: 2012 Dodge Ram RCSB
Rep:38
MOFOGO is on a distinguished road
Originally Posted by xtreme View Post
Commonly called a Track Bar, it basically keeps the rearend centered under the body. Yes, you can add a sway-bar, no problem.
Old 12-23-2012, 12:19 PM
xtreme's Avatar
Color: Grey
Rep:29
Excellent, thank you very much!!!
Old 12-23-2012, 02:07 PM
Ramrodtrucker Ramrodtrucker is offline
Vehicle: 2012 Ram 1500 4X4 Crew Express
Ramrodtrucker is on a distinguished road
I have a rear sway. Small and worthless.
Old 12-23-2012, 09:31 PM
viperrt's Avatar
viperrt viperrt is offline
Vehicle: 2016 Ram RT
Trim Level: RT
viperrt is on a distinguished road
I opted for a larger Hellwig front sway bar and added their rear sway bar which is much larger than the stock rear bar. If you look at your pictures you will note the factory mounting bracket is already in place. Hellwig can supply the missing pieces also.
Old 12-31-2012, 10:01 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
If you decide to go with hellwig but plan on doing an aftermarket exhaust, you will need to check to see if the sway bar will fit. I ended up ordering some addco because I don't have a stock exhaust and I plan on changing what I have even more and didn't want to have problems with the fitment of all of it. From everything I had read addco allows you to have an aftermarket exhaust with no problems.
Supercharged, cammed, other things too!
Old 01-01-2013, 03:47 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
I have a Magnaflow cat-back with the Hellwig rear bar...not even close to having any interference.
Old 01-01-2013, 04:25 AM
Rep:2954
you might want to look at a series of videos that were done to a RAM EXPRESS
to make it more like a good handling Ram Sport Edition
nice mods & it tells you which rear sway bar to use
the videos were done by Stacy David
http://staceydavid.com/projects/drag-n-wagon
Old 01-01-2013, 03:59 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
I'd challenge Stacy David to a road course any day...my truck vs his red truck.
