Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
United Radio
Old 12-23-2012, 10:09 PM
Tivs Tivs is offline
Vehicle: 1997 Ram 2500
Color: Brown
Tivs is on a distinguished road
Default CRAP mileage!
Ok guys im at a loss im still getting crap mileage. im like getting 180 miles to the tank. i kno they arent known for setting mileage recoreds but come on! i changed my plugs and oil doin wires soon (hopefully that helps more) I have a free flowing exhaust with no CATs (I find odd i couldnt find a downstream O2 sensor yet i have no check engine.) Cleaned my TB (looks new) and cone filter. I can literally get on it and it will drop a quarter tank (and slightly come back up) I need help FAST.
Old 12-23-2012, 10:20 PM
Color: Brown
Maybe i have a ghost code for the 02 sensor? How do i do the igniton code check? is it turn on then off then on then it will flash or something?
Old 12-24-2012, 06:19 AM
Color: Brown
so im getting less about 5mpg....lame! 350 miles per tank would be 10mpg
Old 12-24-2012, 09:27 AM
Bully's Performance's Avatar
Bully's Performance Bully's Performance is online now
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
If that is the case there is something wrong, i would check you fuel line for a leak somewhere there is no reason at all you should be getting 5mpg, what mods do you have done to your truck?
Old 12-24-2012, 11:51 PM
Color: Brown
No leaks man ive looked i am grateful this truck doesnt leak a drop of anything. i could see maybe my gauge is way off. it runs sweet, i cant even feel it rumbling in the seat of my pants since i changed the plugs and oil. Its sitting on 285/75/16 Hankook M/Ts load E, free flowing exhaust no cats (couldnt find an o2 sensor yet i have no check engine and doesnt smell like its running rich, and i have a cone filter on the air box. ill try running an octane boost. do u think since i use the cheap gas ill get crappier mileage?
Old 12-26-2012, 09:38 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
Smile
First did it just out of nowhere start the bad mileage? For what it is worth I have had similar issues when removing cats, & having too free of flowing exhaust. Engines with cats seem to perform overall better with them on. You may have more power without them but you pay at the pump. These electronic controlled computer engines seem to do better OVERALL with some back flow pressure. I have a 3" two into one MagnaFlow exhaust on my V-10 it helped the power some, but surely didn't hurt the mileage.
The exhaust shop told me to leave the cats that I would loose more than I gain OVERALL.
Please note: OVERALL I mean best power, mileage, driveablility. You can gain more in one area but as a rule loose in others. The only way around this is to reprogram the computer. There are no programers out there for Dodge V-10 that I'm aware off. I even went to a performance Dodge Dealer & they didn't know of any either.
Old 12-28-2012, 10:53 PM
Color: Brown
Well if i could find a downstream o2 id Do the spark plug fouler trick to fool the computer. i put octane booster in it smoothed up the ride and hopefully better mileage new wires will be the ultimate test.
Old 12-31-2012, 09:05 PM
Vehicle: 1996 SLT
Smile
Plug Fouler s???? They don't work. A buddy of mine put some of those things on an old 62 Ford Ranchero 6cyl. The thing wouldn't even run with them.
Old 01-01-2013, 01:01 AM
Color: Brown
damn ive done it to a few cars and it worked like a dream. for 5 bucks i might just try it...but like i said...cant find a d/s 02 sensor.
Old 01-05-2013, 05:51 AM
Fisher Dave Fisher Dave is offline
Vehicle: 1994 Dodge Ram 3500
Fisher Dave is on a distinguished road
I can get 5 mpg easy out of my v10.. just get stuck in gridlock and it happens every time! Other than that unless im just driving on city streets and being really aggressive with the gas and loaded im still going to be close to 8-9 mpg.
With a moderate load and pulling a trailer at 70 mph ill still get about 9-10 mpg(4.10 gears and 215/85 tires) if im not using the gas pedal like im in the indy 500. If i slow down to about 58 mph I get about 15 mpg. If you do the math thats 30 cents a mile at 70, 20 cents a mile at 58 at todays gas price of $3 a gallon. Next week it will probably be back to $3.86/gal
If you dont have a downstream o2 sensor thats going to cause some issues and a very rich or lean condition... neither is good for your engine. If its running in cold mode(rich) your going to burn some gas. If its running lean youll save some gas, but burn up your engine.
Theres alot of possibilities and im still dealing with it on my v10 truck and my gas milage is fluxuating with a weak link somewhere in the line that powers all my sensors. You could have a crank, tps, eng temp, or map sensor acting up and the engine isnt running efficiently. Sounds like you put oversized tires on the truck, thats going to account for some extra fuel consumption.
Is your truck running good? Good power, any symptoms like hesitation or inconsistant throttle response? Your tranny shifting good and at predictable speeds? Run good/bad cold and changes when it warms up to operating temp? Is it running at operating temp(195).
Its not that hard to hit the exhaust with a brazing rod and drill it and tap it to install an o2 sensor. Get ahold of a good wiring diagram to find out what lead from the pcm to connect to it. You might be dealing with the aftermath of someone elses previous modifications. If my truck was getting 5 mpg id sell it in a hurry too.
There are chips out there but then your stuck using premium fuel and that cost will probably offset the milage increase.
