Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 12-06-2013, 12:22 PM
frecku frecku is offline
Vehicle: 1997 Ram 2500
frecku is on a distinguished road
Default No idle...sort of...
I just bought a 97 Ram 2500 V10 with only 78,000 miles, everything works great, smooth engine and transmission, except initial idle.
When I start the engine I have to gently press on the accelerator otherwise it will not start, I keep the RPM at 1500 for about 30-45 sec minimum, then release and the idle drops to 750.
No sputter or hesitation after that, no difference whether it is cold or hot outside.
The only thing I did so far is put in a STP engine cleaner additive, no change.
I checked all the electric, no broken or loose connections, I will post any codes later today.
Old 12-15-2013, 08:36 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I'm guessing no codes were present? Try running some Seafoam through the tank and also through the intake. You may have a fuel pressure regulator going bad.
Old 12-15-2013, 03:12 PM
Sorry for the delayed response, (NO CODES) with -15F all is on hold, here are my best leads I found online......
Idle air control motor. back of throttle body, get a new one.
most likely the IAC motor is blocked up with grime. Could try cleaning it up a bit while you await the new one.
How to Clean the IAC on a Dodge V10
Read more: http://www.ehow.com/how_7568041_clea...#ixzz2n3jQKPFl
