Old 12-25-2012, 11:08 AM
Dortmunder Dortmunder is offline
Vehicle: 2011 RAM 1500 Sport Quad Cab
Color: Grey
Rep:31
Dortmunder is on a distinguished road
Default Moisture from heater?
This doesn't happen every day, but I have noticed it a couple times.
I'll leave to drive to work, and suddenly all my windows fog up instantly. If I put the defrost on it goes away in less than a minute or so.
But this happened on the highway the other day, and I couldn't see shit while I was going about 110km/h.
It's pretty cold here now, around -15c to -30c, which probably has something to do with it, but it seems like my heater pumps out some moisture at some point.
I usually let the truck warm up for 2-5 minutes before leaving. The block heater is also plugged in and timed to go for about 2 hours before I leave.
Old 12-26-2012, 10:15 AM
sxthemicrewcab's Avatar
sxthemicrewcab sxthemicrewcab is offline
Vehicle: 2011 dodge ram
Trim Level: sport
sxthemicrewcab is on a distinguished road
Same thing happens to me. I have owned two different 4th generations rams and both of them do this. It only seems to happen if it is really cold and I don't warm it up for at least ten minutes.
Mods: diablo sport trinity t1000, total load control airbags
Old 01-01-2013, 01:15 PM
RamSport84 RamSport84 is offline
Vehicle: 2011 Crew Cab Sport
RamSport84 is on a distinguished road
turn on your a/c. sounds counter-intuitive but it removes the moisture from the air and will keep this from happening.
Old 01-07-2013, 01:40 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2011 Crew Cab 1500 Sport 4x4
Color: Black Pearlcoat
Rep:19
blackpearldodge is on a distinguished road
The A/C in the Rams run automatically in the winter, they do so to prevent the exact problem you are describing. Perhaps your A/C unit isn't turning on (blown fuse?) I'd be having a friendly chat with my service department if I were you.
I'm having an issue right now with a mould smell on start up. In our discussion the service guy told me that the A/C unit runs momentarily to rid the system of moisture (no window frost-up).
Once you have Black you'll never go back!
Sport Performance Hood, OEM Mud Flaps, Engine Cover (Hemi Orange), Factory Spray-in Bed Liner, 50 watt - 6000k HID Headlights (low-beam), 35 watt - 4300k HID Fog Lamps, LED License Plate Lights
Old 01-09-2013, 10:22 PM
fishinf1's Avatar
fishinf1 fishinf1 is offline
Vehicle: 2011 Ram
Trim Level: st
fishinf1 is on a distinguished road
Mine does the same thing. Sucks when you leave work and hit the freeway and bam! looking through 3 inch circle of non-fog.
Old 01-10-2013, 04:56 AM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
It's normal, especially when the outside air vent is closed. Think about it, you are recycling moist air we breath out.. And yes the A/C Runs when you turn the defroster setting on regardless of what the LED says, most cars are this way as heat alone will not de fog the inside of the windshield....
Old 01-13-2013, 10:22 PM
fishinf1's Avatar
Vehicle: 2011 Ram
Trim Level: st
You would be correct on that matter, however the ac units are designed to take moisture out of the air. This is why the ac unit turns on during defrost mode. Ram Sucks on this issue. Engine heats up about as quick as a cummins and wipers freeze up quicker.
Old 01-13-2013, 10:27 PM
fishinf1's Avatar
Vehicle: 2011 Ram
Trim Level: st
