Old 12-31-2012, 06:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
yes. The slave cylinder on many gm's is inside the bell housing basically attached to the throwout bearing. There's a hole in the side of the bell housing that has a long bleeder that sticks out that you can access. He was smart and bought a remote mount bleeder line, you can actually see it on top of the engine in the picture of the engine a couple pics up, it's a SS line coming up over the intake manifold and laying in front of the "passenger" side head. We just laid it there during install. Not sure where he ended up mounting it in the car.
He just called me though, and it's ALIVE! Started on the second crank. He said after starting it twice the battery wouldn't turn it over again though so he's getting another battery in the morning.
Sean
Old 12-31-2012, 07:02 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Actually you headed me off at the pass because I was going to suggest the feasibility of installing a remote bleeder. It's refreshing to see (read) of someone using their 6th sense. You know the one we weren't given to start with...common .
Good call
Old 12-31-2012, 08:30 PM
snrusnak's Avatar
Rep:1385
I guess idiots think alike
Should have a video and many pics to upload in the next few days. Eventually when I see him again I'll do a video from in the car. It was fast before and now it will fly.
Sean
Old 12-31-2012, 08:49 PM
Vehicle: 95
Rep:1776
I'm sorry but I take offense just to you suggesting that I might think.
Old 12-31-2012, 08:52 PM
snrusnak's Avatar
Rep:1385
LOL you are halarious
BTW your truck looks good!
Sean
Old 12-31-2012, 08:59 PM
Vehicle: 95
Rep:1776
Thanks and I look forward to the blurry video out the Camaro's window.
Old 01-01-2013, 07:27 PM
snrusnak's Avatar
Rep:1385
Started with a pallet of parts:
Car as it was:
Just after removing the k frame:
Cleaned up short block ready to reassemble:
Homemade gauge to check lifter preload:
Sean
Old 01-01-2013, 07:32 PM
snrusnak's Avatar
Rep:1385
Assembled engine:
Header cut and welded to make the collector not it the floorboard:
Floorboard ready to cut:
Cut out, with new shifter installed:
Engine, 6 speed, k frame all assembled ready to go back in to the car(you can see the remote bleeder line coming out of the bell housing in this pic):
Installing:
(who wears short shorts haha)
And done:
Sean
Old 01-09-2013, 10:48 PM
snrusnak's Avatar
Rep:1385
I guess I forgot to update. The car is in fact running, but his hptuners fails to communicate with the ecm so sent it to get repaired. So although it runs, it needs tuning badly(running on a stock tune) so it's very lean and he's just letting it sit in his driveway to avoid any damage. He should have it tuned sometime in the next week or couple weeks then I'll get some video.
Sean
Old 01-09-2013, 11:21 PM
InDeepWaterBlue's Avatar
Rep:611
damn that's a lot of work but I've always liked that body style of Camaro, they always make great drag cars there's just tons of performance parts available for them. Great job on the build, definitely want a video of this starting up. Props for converting to a manual as well, not sure if I could cut a hole in the tunnel to do that if I was you.
