Old 12-26-2012, 02:25 PM
tachel403's Avatar
tachel403 tachel403 is offline
Vehicle: 2011 Dodge Ram sport quad cab
Trim Level: sport
Color: blue
Rep:71
tachel403 will become famous soon enough
Post 4" Lift Q & A
Hey everyone hope your Christmas was all that you expected. to treat myself for some Christmas gifts i plan on getting a 4" lift. what i wanted to hear from you guys is. What are the pros and cons. how much did you pay for the lift and the installation price. what brand of lift is better and why? does it sit level after installation or do you have to buy extra stuff for that. parts wearing at all because of the lift?
Old 12-26-2012, 03:42 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
well theres 2 ways about it and it really depends on what you need. if you want off road ability id opt for a true 4" suspension lift (1200$+) but honestly if your going there its only like an extra 100 or so for a 6". then there's the easy way out , i went this route as my truck is mostly a pavement queen and my only off road needs are construction sites and dirt roads. level kit or bilstiens (2.75) rear spacer 1" is very slight ass high....and a 1.25" body lift. total cost around 380 without labor...i did this myself and saved that....the shocks and rear spacers are fairly easy but i do recommend a garage compress your springs(not needed for a coil spacer). and the body lift is easy just take your time, but if you opt for a shop install it can get expensive, easily a 4-5hr job. hope this helps.
2011 Hemi RCSB Sport 4x4
Old 12-26-2012, 04:42 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Not many pros and cons when comparing 4" and 6" lifts besides height and tires sizes. Lifts vary depending on brand and but about the same price for install. Not really a better brand, most ofer lifetime warraties. Some brands have more ground clearance, they use different parts to obtain their lifts and some sit higher than other brands. Depedning on which options you get with some brands you can obtain a level look. Most keep a rake bc its there for a reason. The main thing thats gonna wear parts faster is bigger heavier tires and deep offset wheels obviously the wider applying more stress.
Mind officially blown
[CENTER][SIGPIC][/SIGPIC]
Old 12-26-2012, 06:50 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
ok, the reason why im not looking at doing it the cheap way is because i don't want to change the angles on my upper and lower a arms along with my cv joints. i want to keep stock angles that's why i want full 4" lift. also i like the 4" look better than the 6" just personal preference.
Old 12-26-2012, 07:02 PM
candy08's Avatar
Rep:213
Not sure what you mean the cheap way. Any 4" lift is fine for what youre wanting, again confused on the "full" 4" lift also. What size tires you plan on running? Sounds like your minds made up, now just close your eyes and pick one.
Not too up to date on the 4" lifts. I do know some use spacers on the rear and some use replacement coils. Just go to the manufacturers website and read up on em...
Old 12-26-2012, 07:53 PM
Vehicle: 2011 Ram
Rep:141
think he means a full 4" suspension kit, everything required all together, and i cant disagree on the cv angles, im planning on dropping my bilstiens at some point back to 2". i only mentioned the 6" kit because many people opt for the 4" for cost concern not realizeing theres not a big difference....if you want rough county, try them on ebay...they have a best offer option might same ya afew bucks....i saved enough on my body lift to cover shipping and customs fees....and 35's look great on a 4" lift..,..and by cheap way i mean 400$ vs the 1200 for a rough country 4" suspension lift. other brands seem to go up from there.
Old 12-26-2012, 08:29 PM
candy08's Avatar
Rep:213
A 4" suspension lift is a kit...it has everything included. Between your post and the op I was confused lol. As far as cvs and all suspension and drivetrain compenonents are concerned; factory geometry is retained. Newfie your issues dont pertain to a 4" suspension lift. From the sounds of it, you have maxed bilstiens and the rcx body. Completely, completely different than a 4" suspension in all forms, which I think you know. Your post just didnt apply that! Op i wish I knew more about the 4" lifts. Honestly I think the main difference is how the front and rear lifts are achieved.
Newfie wats this 4" lift is for offroad ability!? Whereas the rest arent...you mean like your setup or my setup? Mines a pavement princess as well....just curious tho!
Old 12-26-2012, 08:30 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
yea when i meant full i meant everything ready to go, not just shocks and spacers. i was looking at the billstein 5100s for a long time but after enough research still found out they're hard on your cv's. im planning on going to 35" tires once the stock tires wear out or i might switch in the summer and keep these for winters.
Old 12-26-2012, 08:32 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
and just to clarify this , this is just for looks, minus going down a dirt road here and there.
Old 12-26-2012, 09:31 PM
bootstrap23 bootstrap23 is offline
Vehicle: 2012 Dodge Ram
Trim Level: Sport CC 4x4
Color: Tequila Sunrise Pearl
bootstrap23 is on a distinguished road
any info or opinions on the Mopar 4" lift kits? I too, am looking into a 4" lift and want the whole package. Plan on running 35s and its mostly for the looks
