Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 12-26-2012, 10:07 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Default Another satisfied TLC customer
I installed my air bags last week! I originally "THOUGHT" i was missing some items but the people at TLC went over the list and assured me everything was there. I emailed "TLCJohn" and received a response within the hour (10 pm pacific time). Customer service is fantastic with these guys!! The whole install took me about four hours. I would have been done sooner but i stripped out the bolt on the aluminum mounting plate and had to rethread it. Other than that, the install was smooth. My biggest challenge was deciding where to mount the gage, i ended up mounting it below the steering wheel to the side. Install is clean looking, i might post more pics later. Thanks to "armyof one" also for his how to's. I will follow up when i take the 5th wheel out for a test drive, as soon as the weather clears up a bit.
Old 12-27-2012, 08:41 PM
Color: black/gray
Default More Pics
Old 12-27-2012, 08:45 PM
Color: black/gray
Default Compressor mount
Mounted the compressor on the side frame under the driver door.
Old 12-31-2012, 03:00 PM
scuba0331's Avatar
scuba0331 scuba0331 is offline
Vehicle: 2014 Ram 3500 CTD Crew Cab
Trim Level: Bighorn
Color: Deep Cherry Red
Rep:20
scuba0331 is on a distinguished road
Nice! My wife gave me the air bags for Christmas! I can't wait to install!
Thanks for the pics and nice job!
[SIGPIC][/SIGPIC]
Old 01-03-2013, 12:44 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
You have a wonderful wife!
Enjoy the Total Control!
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 01-13-2013, 08:10 PM
Color: black/gray
Default Update on TLC
Hooked up the 5th wheel today for a road test. I have a 27' about 6500 lbs. The truck sits level! YES! just need about 8 lbs of air in the bags. Improved handling, much less bounce. Braking seems a bit easier too but not sure if thats just due to adjustment of my trailer brake. The catalytic converter got hot enough to melt the tubing so i have to re route that further away, maybe i'll place it behind the fender flare. Not a big deal, lesson learned. I can still inflate the airbags, just cant see ho much pressure is in them.(It was the tubing between the gage and compressor. ) I'll take care of it toorrow. I took pics but they didnt come out(New camera) so ill have to post them later.
