Old 12-27-2012, 02:29 AM
WesGee's Avatar
WesGee WesGee is offline
Vehicle: 2009 Dodge Ram
WesGee is on a distinguished road
Default Need help with tire size
Im currently running Goodyear 275/65/20s on my 09 Ram, Its 4x4 with a leveling kit. I recently discovered my upper control arms are rubbing the inside sidewall of my tire when I hit a bump or something. I need to buy new tires anyways so I'd like some suggestions on size, I like the height of my current tire and could even go taller, its the width thats the problem. I dont want to use spacers. Thanks for any input.
2009 Dodge Ram 4x4-Volant CAI-Flowmaster Exhaust-Leveling Kit-HID Headlights and Foglights-Step Bars-(4) KC Long Range Lights
Old 12-27-2012, 08:43 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
That seems really odd. Are you certain you are running 275/65/20?? Are you running the stock rims? The stock 20" tires are the same width as what you are running but just one size shorter (275/60/20). On stock rims with 275/65 there is no reason it should be rubbing anything. You should actually be able to run one size wider like a 285/60 or 285/65. Generally it's wider than 285 that becomes a problem for the fourth gen trucks.
Old 12-28-2012, 02:50 AM
InDeepWaterBlue's Avatar
Rep:611
You may want to get your truck aligned. My 285/45/22's don't rub anything, and your tire definitely shouldn't be rubbing on the control arm, if anything at full lock you might touch the sway bar. I had that issue with my front left tire, and it was due to improper alignment.
