Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 12-27-2012, 04:06 PM
Kindafast's Avatar
Kindafast Kindafast is offline
Vehicle: 2004 Hemi GTX
Color: Green
Kindafast is on a distinguished road
Default Blower Fan ????
Hey Guy's my heater blower fan only works on high. It does not even try to come on on the lower settings. Do you think it could be the switch ?? Any opinions welcomed...
Old 12-27-2012, 04:14 PM
wef3rd wef3rd is offline
Vehicle: 2004 Dodge Ram 2500
Color: Brown
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
wef3rd is on a distinguished road
Default blower
If you got power coming out of the switch I would replace the blower motor resistor. Had same problem on another vehicle and that's what it was.
Old 12-27-2012, 04:32 PM
Resident Technician
Rep:1915
Don't forget to check the connector when you replace the faulty resistor. They are known to melt due to the heat from the resistor and cause problems. If you need a replacement, the dealer can get you one to splice in.
Old 12-27-2012, 04:35 PM
Kindafast's Avatar
Color: Green
Cool Thanks, Where is the resistor located ? Can I get to it fairly easy ??
Old 12-27-2012, 06:28 PM
Kindafast's Avatar
Color: Green
Found It !!!! Thanks
Old 01-02-2013, 11:55 PM
cruzin55 cruzin55 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: larmie
cruzin55 is on a distinguished road
I have a problem with my blower motor not working it changes speeds on its own or will not come on right away after restarting the truck the ck enging lite comes on and a p0480 code comes up and Ive checked everything Ive been told it could be the ecm going bad anyone able to help ??
