Need Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-27-2012, 09:47 PM
pruitt146 pruitt146 is offline
Vehicle: 2004 Doge Ram
pruitt146 is on a distinguished road
Default Need Help
Ok guys I will be as detailed as I can about this but I'm no expert. I have a leak (oil, I think) coming from the line that runs from the cooler to the top port on whatever the thing is called attached to the rack and pinion. I don't know if you call it a steering box or what. All I do know is the steering shaft comes down and connects to it. There are 4 lines that come out of this "thing" and two are small and feed back into the rack. The other two are larger and one goes to the power steering tank ( I think) and the other goes to the cooler. It is leaking at the end that goes into the "steering box". Can someone please tell me a) can I just put a hose clamp on it to stop the leak or b) what it is called so when I go to the parts store I don't look like a fool. Thanks.
Old 12-28-2012, 06:23 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Could you take a picture? I don't think the power steering has a cooler on it, but I could always be wrong. So maybe its your power steering reservoir. If its leaking you might want to replace the hoses, and the clamps.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 12-28-2012, 05:04 PM
http://shop.advanceautoparts.com/buy...rt-rp7298.html
Here is a picuture of a new rack from Advance Auto Parts. The piece I am asking about is the piece on the top left of the rack. It looks like it has a small gear sticking out the top of it.
Old 12-28-2012, 05:26 PM
Resident Technician
Rep:1915
Given the age of your truck and the fact that the line has likely dried out somewhat, I would replace it.
Old 12-28-2012, 05:33 PM
Ok. Can you tell me what to ask for at the parts store? Is it a steering box cooler line?
Old 12-28-2012, 05:43 PM
Resident Technician
Rep:1915
I would call it a power steering return line ans since the cooler is in the middle, you need to specify that it's the one between the gear and cooler.
